Marine 440 crank #195173
01/16/09 01:48 PM
01/16/09 01:48 PM
Canada
RobR Offline OP
RobR  Offline OP
Canada
I have a friend in BC that's fighting with a rear main leak in a 440...
I very sure that Chry never had a reverse rotation crank with the rear seal scallops going in the opposite direction to pass car engines.They all used rope seals.I know Ford and Chev had specific L/R rotation cranks but I'm unsure about the 440's.
Anyone know for a fact ????
It's a rear sump pan and I told him to baffle it to keep the oil away from the rear on excelleration...Something is overloading the rear seal and the reverse rotation seal surface is a very very very long shot...oil splashing to the rear on acceleration is the likely cause...
Anyone know or have an idea.
Any input would be muchly appreciated.
Rob
Re: Marine 440 crank [Re: RobR] #195174
01/16/09 05:38 PM
01/16/09 05:38 PM
I have had 440 steel cranks with the things in the other direction--can cause a headache--you can polish the area smooth and the rubber seal will do fine--that is a rare problem but have been there done that in the past--I bet it is some other problem back there--the newest Fel Pro supplied rubbers are a tad shorter and don't stick up from the seal holder enough--PIA! Put the seal holder on a rod cap cutter, knock 010 off it and make sure the seal is protruding--you will be fine
Re: Marine 440 crank [Re: RobR] #195175
01/16/09 06:28 PM
01/16/09 06:28 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
I had a reverse rotation marine 440 before..and yes, the scallop marks went the other direction from a 'normal' 440..
I still have the cast aluminum oil pan and cast iron timing cover from it still
Re: Marine 440 crank [Re: OzHemi] #195176
01/17/09 12:33 AM
01/17/09 12:33 AM
Canada
RobR Offline OP
RobR  Offline OP
Canada
Thanks OZ..
Him being in BC with all the water craft in that province it must be a marine crank...
Re: Marine 440 crank [Re: RobR] #195177
01/17/09 12:44 AM
01/17/09 12:44 AM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Re: Marine 440 crank [Re: OzHemi] #195178
01/17/09 05:09 AM
01/17/09 05:09 AM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
I am curious if this was balanced?
Re: Marine 440 crank [Re: RobR] #195179
01/17/09 08:24 AM
01/17/09 08:24 AM
Big Sky Country
MO_PA Offline
MO_PA  Offline
Big Sky Country
The aluminum seal retainer could be cracked/broken from a, too long, pan
bolt having been installed.
Re: Marine 440 crank [Re: 500ciDuster] #195180
01/17/09 10:43 AM
01/17/09 10:43 AM
Canada
RobR Offline OP
RobR  Offline OP
Canada
I have no idea if it was balanced or not ...
The rear seal holder was checked for any cracks and it was machined flat...
I'll talk to him some time this morning and see how hes making out.
Thanks for all the suggestions guys..
Rob
