Re: 33 radiator???
[Re: 80arrow]
#1947668
11/08/15 08:07 PM
11/08/15 08:07 PM
Posts: 414 Indiana
Pentastar440
Indiana
http://www.prchotrod.com/They will build a radiator to your specs , they will build a shroud with a Spal fan built in . They built the radiator for my '38 , it cools great with my 408 .
'65 Belvedere II - 446-Indy,727 transbrake,Dana 4.56
'38 Plymouth 4Dr - 408SixPack, A518, Dana60 4:10
Re: 33 radiator???
[Re: 80arrow]
#1948018
11/09/15 12:38 PM
11/09/15 12:38 PM
Posts: 7,506 Az
Crizila
Az
My 33 is not a stock configuration ( cowl is laid back farther than stock and top is chopped ), but I used a Speedway aluminum 32 Ford Rad. that I had to make some miner mods to ( upper tank)for it to fit my application. On the door glass, just make yourself a cardboard template that fits your glass runners and take it to your local glass company and they can cut it for you.
Fastest 300
Re: 33 radiator???
[Re: 80arrow]
#1949210
11/11/15 02:47 AM
11/11/15 02:47 AM
Posts: 7,506 Az
Crizila
Az
Thanks guys. Crizila, I was wondering if a 32 or 33 Ford rad would be the same. The car has the stock grill and hood. I'll have to get it here and do some measuring. My 32 Ford rad. Filler neck relocated and corners cut off top tank.
Fastest 300
