33 radiator??? #1947438
11/08/15 11:28 AM
11/08/15 11:28 AM
in front of the computer
8
80arrow Offline OP
80arrow  Offline OP
Hi guys. Where do you guys suggest I get a radiator with a trans cooler in it? Or even one without? Its for a 33 Plymouth. Also how about a spot to get the door glass? The glass in my dad's 33 Plymouth seems sloppy, almost like its not long enough front to back, and it seems to bind a little as is goes up. Thanks, Clint
Re: 33 radiator??? [Re: 80arrow] #1947444
11/08/15 11:42 AM
11/08/15 11:42 AM
WI
W
wannadrag Offline
wannadrag  Offline
W
WI
For the hot rods I always get the glass from this guy.
http://www.bobsclassicautoglass.com/
Re: 33 radiator??? [Re: 80arrow] #1947668
11/08/15 08:07 PM
11/08/15 08:07 PM
Indiana
P
Pentastar440 Offline
P
Indiana
http://www.prchotrod.com/
They will build a radiator to your specs , they will build a shroud with a Spal fan built in . They built the radiator for my '38 , it cools great with my 408 .
'65 Belvedere II - 446-Indy,727 transbrake,Dana 4.56
'38 Plymouth 4Dr - 408SixPack, A518, Dana60 4:10
Re: 33 radiator??? [Re: 80arrow] #1948018
11/09/15 12:38 PM
11/09/15 12:38 PM
Az
Crizila Offline
Crizila  Offline
Az
My 33 is not a stock configuration ( cowl is laid back farther than stock and top is chopped ), but I used a Speedway aluminum 32 Ford Rad. that I had to make some miner mods to ( upper tank)for it to fit my application. On the door glass, just make yourself a cardboard template that fits your glass runners and take it to your local glass company and they can cut it for you.
Fastest 300
Re: 33 radiator??? [Re: 80arrow] #1949049
11/10/15 10:23 PM
11/10/15 10:23 PM
8
80arrow Offline OP
80arrow  Offline OP
Thanks guys. Crizila, I was wondering if a 32 or 33 Ford rad would be the same. The car has the stock grill and hood. I'll have to get it here and do some measuring.
Re: 33 radiator??? [Re: 80arrow] #1949137
11/11/15 12:27 AM
11/11/15 12:27 AM
alabama crimson tide
N
notweak2 Offline
notweak2  Offline
N
You cann't go wrong with a Ron Davis radiator.
Re: 33 radiator??? [Re: 80arrow] #1949210
11/11/15 02:47 AM
11/11/15 02:47 AM
Az
Crizila Offline
Crizila  Offline
Az
My 32 Ford rad. Filler neck relocated and corners cut off top tank.
Fastest 300
Re: 33 radiator??? [Re: Crizila] #1950167
11/12/15 10:10 PM
11/12/15 10:10 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
sloppy glass may mean the weatherstrip in the glass channel is wornout---binding on rolling up may mean the window channel needs to be adjusted...dont need new glass unless you break it....
