Building a 1996 Magnum 360 ? about pistons #1947329
11/08/15 01:14 AM
11/08/15 01:14 AM
Ohio
Dakotamecrazy Offline OP
Ohio
Does anyone have any feedback on Icon forged pistons. I am looking at a rotating assy from Jegs that offers Icon pistons. I am curious are they as good as Mahle or Probe? I noticed they cost as much as Mahle does. Is there a better set I should be looking for? I am putting the motor into a 3400 pound Dakota for street/strip use. The street use is driving it to the track.
Thanks Chris
Re: Building a 1996 Magnum 360 ? about pistons [Re: Dakotamecrazy] #1947342
11/08/15 01:46 AM
11/08/15 01:46 AM
WI. U.S.A.
DusTed74 Offline
DusTed74  Offline
WI. U.S.A.
I'm running them in my 408. The engine has been together for over 3 years now and no problems at all.
I say go with them.
Ted
Re: Building a 1996 Magnum 360 ? about pistons [Re: Dakotamecrazy] #1947899
11/09/15 02:49 AM
11/09/15 02:49 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Hard to beat the mahle, they are much nicer (hard anodized, very light weight because of the struted design on the bottom side much like a formula 1 or nascar piston)than icon and come with rings.
Re: Building a 1996 Magnum 360 ? about pistons [Re: Dakotamecrazy] #1947907
11/09/15 03:05 AM
11/09/15 03:05 AM
jacksonville,FLORIDA
slammedR/T Offline
slammedR/T  Offline
I prefer the wiseco pistons, i had great success with SRP pistons but i started to use more nitrous than they could handle. I know wiseco offersd a shelf piston in the better 2618 material and I believe they come hard coated. My custom wiseco pistons are SWEET!! and are gas ported and hard coated.
2000 Dakota R/T, 408 magnum, 727, Indy heads
1000cfm 4150 carb, 93 octane fuel.
motor; 10.258 @ 132.78
200 shot; 9.262 @ 144.69
racemagnum
Re: Building a 1996 Magnum 360 ? about pistons [Re: slammedR/T] #1948196
11/09/15 06:37 PM
11/09/15 06:37 PM
dogdays Offline
dogdays  Offline
Mahle. then Icon, then Probe is how I would rank them. Icon pistons are the forged variety of United Engine and Machine's Silv-o-lite/Keith Black/Icon lineup.
If you were looking for a really special piston you'd not be looking for a kit anyhow. I don't believe the block can take what an Icon piston can. (or a JE/SRP or Ross or Wiseco/ProTru or CP or RaceTech) or a Speed-Pro for that matter.
There was a time when the only forged pistons one could find were TRWs or Arias or Venolia or ForgedTrue, maybe a couple4 others, but they didn't have complete product lines and cost a fortune, except the TRWs. So you'd buy a TRW if it was available for your engine and you could possibly send them to a guy who'd machine some weight out of them. The idea of a lightweight forging available in all sorts of configurations off the shelf was pie-in-the-sky, we never believed it was possible.
R.
Re: Building a 1996 Magnum 360 ? about pistons [Re: dogdays] #1948289
11/09/15 09:04 PM
11/09/15 09:04 PM
slammedR/T Offline
slammedR/T  Offline
R.
I know for 100% fact that stock magnum block could handle what a custom piston would. I'm at 815whp on factory stock block and still kicking it.
racemagnum
Re: Building a 1996 Magnum 360 ? about pistons [Re: Dakotamecrazy] #1948651
11/10/15 11:24 AM
11/10/15 11:24 AM
CJD AUTOMOTIVE Offline
Everybody has there preference. I like CP, but Mahle, etc are all good. Don't waste your money on gas ports for a street driver. They will be plugged with carbon in just a few hundred miles.
Still think it is amazing slammedR/T is putting that amount of power through a stock magnum block and it lives!
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
www.CJDAUTOMOTIVE.com
904-400-1802
"I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
Re: Building a 1996 Magnum 360 ? about pistons [Re: Dakotamecrazy] #1948801
11/10/15 03:54 PM
11/10/15 03:54 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
The bottom end is a lot like a T/A block on the magnum, certainly can take more than a normal LA block.
