318 block #194680
01/15/09 09:19 PM
01/15/09 09:19 PM
sweden
the swede Offline OP
sweden
Hi Guys I have a 318 block from 68 and im about to use it with a 4 inch crank,and im looking at 500 to 550 hp and its a 2 bolt block.
what do you think guys will the block hold for that crank???
Re: 318 block [Re: the swede] #194681
01/15/09 09:33 PM
01/15/09 09:33 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
yup
2017 Grand Cherokee Overland
Re: 318 block [Re: patrick] #194682
01/15/09 09:37 PM
01/15/09 09:37 PM
yup
Re: 318 block [Re: Cab_Burge] #194683
01/15/09 10:12 PM
01/15/09 10:12 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Block will hold just fine, asumeing no dramatic core shift of course. One thing I would think about is better main caps, they are punier than a 340 cap but the block webbing is the same. One over looked advantage to the 318 blocks is less grinding for roller lifters, and if you had a roller block then no grinding required.
Re: 318 block [Re: the swede] #194684
01/15/09 10:23 PM
01/15/09 10:23 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Maybe? Your using the small 318 bore?
Re: 318 block [Re: goldmember] #194685
01/16/09 08:06 AM
01/16/09 08:06 AM
sweden
sweden
Thanks for your answers guys I will propaberly bore it 0.30
Re: 318 block [Re: the swede] #194686
01/16/09 07:05 PM
01/16/09 07:05 PM
I've heard the early 318's had thicker cylinder walls,sonic testing will tell you.I've been looking for a early 318 67-70 for a stroker build myeslf.
Re: 318 block #194687
01/17/09 11:07 AM
01/17/09 11:07 AM
Tampa, FL
tpabayflyer Offline
tpabayflyer  Offline
Tampa, FL
My 70 318 stroker went together perfectly and is a great little motor. I may be upgrading my project to a 451 I have
had sitting around. Wayne, shoot me a PM I may be able to help you out.... TBF
71 Challenger 528 Hemi project
09 Gr Cherokee 5.7 hemi in da house!!
Re: 318 block #194688
01/17/09 12:32 PM
01/17/09 12:32 PM
sweden
sweden
Hi:yes the earlier blocks had thicker walls and i think the 68 block has it
