727 trans date stamp questions #1945936
11/05/15 10:08 PM
11/05/15 10:08 PM
tennessee,usa
mattsmopars Offline OP
tennessee,usa
So not to high jack another thread going on I started this one. I had a question about dates on a 727 that I have. It is part numbered for some 67- early 68 440 and 383 HP applications.
The part number stamp is H2801541 dated 3351 126.
The 10,000 day date looks to be Sept. 30th 1970.
So would this just be a service replacement trans or something? The main case casting date is 1966.
I have also noticed most 727 trans that are dated for the cars in that time frame have a PK for the assembly plant and this one has an H. Those are my main questions and thanks in advance.
Just looking to better understand the situation.
Matt
Re: 727 trans date stamp questions [Re: mattsmopars] #1946050
11/06/15 01:04 AM
11/06/15 01:04 AM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
I want to know too. Maybe the calendar is being read wrong? just asking. I've got about 25 727s if someone cares to come over and decipher them.. Some of those have 7 digits instead of 8.
Re: 727 trans date stamp questions [Re: mattsmopars] #1946251
11/06/15 01:02 PM
11/06/15 01:02 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Chrysler had millions of transmission cases cast so I wouldn't be surprised to find a 66 cast trans with a 1970 ASSEMBLY date stamped on it .
Does it have a VIN stamped on it ?
Cast in 66 , I assume it does not have the raised VIN pad on the right side of the bell ?
Re: 727 trans date stamp questions [Re: mattsmopars] #1946268
11/06/15 01:24 PM
11/06/15 01:24 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
When did the DPCD logo stop ?
Re: 727 trans date stamp questions [Re: JohnRR] #1946281
11/06/15 02:06 PM
11/06/15 02:06 PM
tennessee,usa
tennessee,usa
Your correct no vin pad.
Matt
Re: 727 trans date stamp questions [Re: mattsmopars] #1946385
11/06/15 04:42 PM
11/06/15 04:42 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Matt
At the point they needed to have the pad they probably pushed all the leftover earlier cases into the stack for REPLACEMENT trans cases.
I'm trying to remember if I have ever seen/had a trans with the vin stamped into the case without a pad on the side ?
Re: 727 trans date stamp questions [Re: JohnRR] #1946547
11/06/15 08:52 PM
11/06/15 08:52 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Hey that looks like a HEMI Trans that's been restamped to a 440,
LOL!! stirthepot
Re: 727 trans date stamp questions [Re: JohnRR] #1947068
11/07/15 06:41 PM
11/07/15 06:41 PM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
I'm pretty sure some 68's are stamped on the top of the trans/engine mating surface, readable when assembled by looking down the front of the firewall.
Not sure if all plants did this, and if only certain motor/trans combos.
Re: 727 trans date stamp questions [Re: mattsmopars] #1947128
11/07/15 08:51 PM
11/07/15 08:51 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
I have a 67 GTX with original drivetrain, 66K original, bought from original owner. It came from St Louis plant, 927 SPD. the trans has a similar stamp to the one pictured above. H2801541 3395245. Maybe this is a common stamp from the H trans plant. This numbering that seemingly makes no sense, I have seen it previously on the same trans part number.
Re: 727 trans date stamp questions [Re: mattsmopars] #1947212
11/07/15 10:18 PM
11/07/15 10:18 PM
tennessee,usa
tennessee,usa
I would really like to know what the truth of the matter is on the date. I had a guy a few years back come to look at it for his 67 R/T, and did not want it due to the fact he didn't think the date matched up.
I would like to know the truth as well as I look for a 68 hemi Trans for my bee.
Matt
Re: 727 trans date stamp questions [Re: mattsmopars] #1947306
11/08/15 12:25 AM
11/08/15 12:25 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Anyone else with a 67? Please check the trans to see the numbers.
I Have seen this style of number several times. The car I have is a known original. I did freshen the trans and every piece with a date has 66 on it. It was never apart before.
Re: 727 trans date stamp questions [Re: mattsmopars] #1947626
11/08/15 06:25 PM
11/08/15 06:25 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Here's another example of a '67-'68 trans with a '72 build date. The only way the build date makes sense is to add a 2 in front of the stamped date, i.e. 2392 is 2-14-68. Note the difference in the stamp depth of the various characters. (the J, 5 and 0)
Re: 727 trans date stamp questions [Re: John_Kunkel] #1947647
11/08/15 07:16 PM
11/08/15 07:16 PM
tennessee,usa
tennessee,usa
Adding the 2 in front would help make some since of the date I guess. It would change the date on my "541" trans to Dec.19 1967.
Here is another 67-68 trans from ebay that is from the "PK" assembly plant so they must be dated different as they have a 4 digit date on them. Guessing its a plant to plant thing?
Matt
Re: 727 trans date stamp questions [Re: mattsmopars] #1949060
11/10/15 10:38 PM
11/10/15 10:38 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
Matt - Here are a few pics of the hemi trans in my 68 Road Runner. This is the original trans. One thing that that I notice is the "K" at the end of the part number.
PK2801544K 2413 0178
2413 = 6 March 1968
0178 = number sequence that day
My car was a Lynch Road build, 4 May 1968.
Re: 727 trans date stamp questions [Re: mattsmopars] #1949087
11/10/15 11:09 PM
11/10/15 11:09 PM
tennessee,usa
tennessee,usa
Thanks Jim! Now if I can figure all the other dates out we will be doing good! LOL.
Matt
