Re: 727 trans date stamp questions
[Re: mattsmopars]
#1946251
11/06/15 01:02 PM
11/06/15 01:02 PM
Posts: 75,004 U.S.S.A.
JohnRR
U.S.S.A.
Chrysler had millions of transmission cases cast so I wouldn't be surprised to find a 66 cast trans with a 1970 ASSEMBLY date stamped on it .
Does it have a VIN stamped on it ?
Cast in 66 , I assume it does not have the raised VIN pad on the right side of the bell ?
[Re: JohnRR]
#1946281
11/06/15 02:06 PM
11/06/15 02:06 PM
Posts: 3,136 tennessee,usa
mattsmopars
tennessee,usa
Cast in 66 , I assume it does not have the raised VIN pad on the right side of the bell ? Your correct no vin pad. Matt
[Re: mattsmopars]
#1946385
11/06/15 04:42 PM
11/06/15 04:42 PM
JohnRR
U.S.S.A.
Cast in 66 , I assume it does not have the raised VIN pad on the right side of the bell ? Your correct no vin pad. Matt At the point they needed to have the pad they probably pushed all the leftover earlier cases into the stack for REPLACEMENT trans cases. I'm trying to remember if I have ever seen/had a trans with the vin stamped into the case without a pad on the side ?
[Re: JohnRR]
#1947068
11/07/15 06:41 PM
11/07/15 06:41 PM
Posts: 15,753 Jefferson State
srt
ESYC
ESYC
Jefferson State
I'm trying to remember if I have ever seen/had a trans with the vin stamped into the case without a pad on the side ? I'm pretty sure some 68's are stamped on the top of the trans/engine mating surface, readable when assembled by looking down the front of the firewall. Not sure if all plants did this, and if only certain motor/trans combos.
[Re: mattsmopars]
#1947626
11/08/15 06:25 PM
11/08/15 06:25 PM
Posts: 25,784 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Here's another example of a '67-'68 trans with a '72 build date. The only way the build date makes sense is to add a 2 in front of the stamped date, i.e. 2392 is 2-14-68. Note the difference in the stamp depth of the various characters. (the J, 5 and 0)
[Re: John_Kunkel]
#1947647
11/08/15 07:16 PM
11/08/15 07:16 PM
mattsmopars
tennessee,usa
Here's another example of a '67-'68 trans with a '72 build date. The only way the build date makes sense is to add a 2 in front of the stamped date, i.e. 2392 is 2-14-68. Note the difference in the stamp depth of the various characters. (the J, 5 and 0) Adding the 2 in front would help make some since of the date I guess. It would change the date on my "541" trans to Dec.19 1967. Here is another 67-68 trans from ebay that is from the "PK" assembly plant so they must be dated different as they have a 4 digit date on them. Guessing its a plant to plant thing? Matt
