Anyone sell ac rallye dash trim 70 B #1945821
11/05/15 07:24 PM
11/05/15 07:24 PM
kentucky
roadrunner7020 Offline OP
kentucky
I'm currently building a rallye dash for my 70 satellite it will not be all factory plan on going with something like classic dash. However I have an ac car and can only find non ac lower pieces for sale new. Other than switches and the dash cap will anything else transfer over from the standard dash? Thanks in advance!
Re: Anyone sell ac rallye dash trim 70 B [Re: roadrunner7020] #1945886
11/05/15 09:02 PM
11/05/15 09:02 PM
Dayton, WA
wesgtx440 Offline
wesgtx440  Offline
Dayton, WA
I'm pretty sure the glovebox door is the same. You mentioned the switches? while the switches themselves are the same, the rocker switch is different between the non-rally and rally dash IIRC. non-rally uses a narrow, silver rocker. Rally dash uses wide chrome rockers. They can be changed though by pushing out the tiny roll pin and putting the correct ones on, and re-installing the roll pin.
68 Charger R/T 440 auto
Re: Anyone sell ac rallye dash trim 70 B [Re: roadrunner7020] #1945927
11/05/15 09:55 PM
11/05/15 09:55 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
You can use the LH lower plastic piece, the steering column cover & glovebox door from a non a/c rallye dash car. Only the center lower piece is different for the a/c cars. This has the center a/c vent in it. You will also need the two end vents. I believe these are the same for rallye and non rally dash.
I assume you already know that you will need a rallye dash frame as well.....your non rallye dash frame will not work.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: Anyone sell ac rallye dash trim 70 B [Re: roadrunner7020] #1945933
11/05/15 10:04 PM
11/05/15 10:04 PM
Lansing, MI
Lansing, MI
Items that will transfer from 70 non rallye dash to rallye dash are:
Map light
dash pad
radio
radio speaker
defrost vents & ducts
a/c vents and ducts
You will have to change all plastic trim and switches.
