Do you seal, or put teflon tape on your fuel pump fittings?
#1944951
11/04/15 12:07 PM
11/04/15 12:07 PM
Posts: 7,541 Albany, NY
67SATisfaction
The member whose name is actually Art
Albany, NY
Guys, Gals,
I get a persistent little drip of fuel from the brass nipple that screws into the fuel pump housing. I've tightened it, and it seems better, but still a bit of moist fuel comes past the threads.
Do I keep tightening the brass fitting, or do you guys use that plumber's teflon tape or some kind of sealant at these fittings?
I believe I have a small jar of white goop sealant from NAPA that is fuel resistant.
Thanks, - Art
65 Satellite hardtop 361/4bbl console 727 2.76 67 Satellite convert 383/2bbl column 727 3.23 67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd 67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd 71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd 82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle 75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF 77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF 07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
Re: Do you seal, or put teflon tape on your fuel pump fittings?
[Re: 67SATisfaction]
#1944959
11/04/15 12:22 PM
11/04/15 12:22 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
[Re: roadhazard]
#1944982
11/04/15 01:13 PM
11/04/15 01:13 PM
RapidRobert
What Roadhazard said, take the fitting off & inspect the cone interface on both sides which is where it seals. reflare it slightly then use some sealant on the threads to take care of any minor seepage from a less than perfect union but considering that it might get worse on down the line plus the severity of a fuel leak, I would likely cut/reflare the line and or get a new fitting especially if it was on the pressure side going to the carb
#1945007
11/04/15 02:21 PM
11/04/15 02:21 PM
Posts: 7,369 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
I get a persistent little drip of fuel from the brass nipple that screws into the fuel pump housing. It seems like he's saying the fitting is leaking at the fuel pump....not the line/fitting connection. Isn't the fuel pump pipe thread? Pipe thread should seal itself shouldn't it? I wonder if the fitting has a small crack in it?
#1945009
11/04/15 02:22 PM
11/04/15 02:22 PM
Posts: 15,408 Omaha Ne
TJP
Omaha Ne
First thing to establish is are you dealing with pipe threads or an inverted flare fitting. Pipe threads require sealant, several options are available. Inverted flare fittings do not require sealant.
[Re: TJP]
#1945051
11/04/15 03:52 PM
11/04/15 03:52 PM
Challenger 1
Cincinnati, Ohio
First thing to establish is are you dealing with pipe threads or an inverted flare fitting. Pipe threads require sealant, several options are available. Inverted flare fittings do not require sealant. This^^^^^ And use pipe dope on tapered pipe threads around fuel systems, not tape. Because tape will wick fuel(turns yellow) and is hell if you ever remove the fitting because little pieces of teflon tape will be everywhere and hard to keep out of your fuel system. And if you apply the tape wrong to begin with you will have tape in your fuel system from the get go. Avoid teflon tape around fuel systems is my advise.
[Re: burdar]
#1945053
11/04/15 03:54 PM
11/04/15 03:54 PM
Challenger 1
Cincinnati, Ohio
I get a persistent little drip of fuel from the brass nipple that screws into the fuel pump housing. It seems like he's saying the fitting is leaking at the fuel pump....not the line/fitting connection. Isn't the fuel pump pipe thread? Pipe thread should seal itself shouldn't it? I wonder if the fitting has a small crack in it? Nope pipe fittings need a thread sealer, even brass fittings do.
[Re: Challenger 1]
#1945081
11/04/15 04:58 PM
11/04/15 04:58 PM
Posts: 2,592 None
71rm23
None
I get a persistent little drip of fuel from the brass nipple that screws into the fuel pump housing. It seems like he's saying the fitting is leaking at the fuel pump....not the line/fitting connection. Isn't the fuel pump pipe thread? Pipe thread should seal itself shouldn't it? I wonder if the fitting has a small crack in it? Nope pipe fittings need a thread sealer, even brass fittings do. I agree!
#1945152
11/04/15 06:39 PM
11/04/15 06:39 PM
Posts: 13,601 md
mopars4ever
md
[Re: burdar]
#1945285
11/04/15 10:31 PM
11/04/15 10:31 PM
67SATisfaction
Albany, NY
Thanks for your responses - I get a persistent little drip of fuel from the brass nipple that screws into the fuel pump housing. It seems like he's saying the fitting is leaking at the fuel pump....not the line/fitting connection. Isn't the fuel pump pipe thread? Pipe thread should seal itself shouldn't it? I wonder if the fitting has a small crack in it? Yes. It's the brass fitting here: The leak appears to be getting past the brass nipple's threads where it screws into the metal housing of the fuel pump. But Thanks for your responses - What I take away here is I can safely try using some standard parts-store sealant to try and stop this. NOT teflon tape. I'll be wearing a new cologne tonight! - Art
[Re: screamindriver]
#1945395
11/05/15 12:38 AM
11/05/15 12:38 AM
Posts: 1,837 South Bend
John Brown
South Bend
I've always used permatex #2 on any threads that needed sealing... Yep, even had to use it on the cheap imported water pipes when I replumbed my water heater.
