Need help decoding 70 Cuda broadcast sheet #1943907
11/02/15 08:31 PM
11/02/15 08:31 PM
Lansing, MI
70gtx440dana Offline OP
Lansing, MI
Hoping some of our resident E body experts can provide decode info for this 70 Cuda broadcast sheet. Trying to help out a friend whom owns the car. This early sheet is a bit hard for me to understand as compared to the proper later 70 sheet. Also, this car is believed to be an original N96 shaker car. However this area of the sheet is missing. Are there any other clues on this sheet that would indicate it being a shaker car? Thanks in advance for any help!!!!
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: Need help decoding 70 Cuda broadcast sheet [Re: 70gtx440dana] #1943923
11/02/15 09:05 PM
11/02/15 09:05 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Need to be at home with a 70 Series F sheet to fully translate
Re: Need help decoding 70 Cuda broadcast sheet [Re: 70gtx440dana] #1943931
11/02/15 09:18 PM
11/02/15 09:18 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Line 10, see the six in the middle? N96- Shaker hood.
Re: Need help decoding 70 Cuda broadcast sheet [Re: Alaskan_TA] #1943937
11/02/15 09:25 PM
11/02/15 09:25 PM
Detroit Michigan
1971HEMICUDA Offline
Detroit Michigan
Alaskan has it correct. That is a nicely optioned Cuda.
Re: Need help decoding 70 Cuda broadcast sheet [Re: Alaskan_TA] #1943970
11/02/15 10:20 PM
11/02/15 10:20 PM
Lansing, MI
Lansing, MI
Ahhhh....thanks for the info. Car has correct cable grommet in firewall so I was fairly certain it may be an N96 car. Car had some front end damage early on and now wears a rallye hood. I would appreciate any additional info. Things I know are:
440-6 auto
FE5 red
white interior
auto with console
Dana 60
am/fm radio
Really would like to know more about stripes, rear gear (think it's a 4.10 car), wheels & tires etc. I look forward to more replys.
Re: Need help decoding 70 Cuda broadcast sheet [Re: 70gtx440dana] #1943973
11/02/15 10:28 PM
11/02/15 10:28 PM
Alabama
BigMoneyLewis Offline
Alabama
A22 Front and rear rubber bumpers, V6X Black hockey stick, A32 4:10 dana .
No real diffrence between these sheets and the full color 70 sheets as far as codes , etc.
Greg
gregward@mchsi.com phone 256-852-0955
Re: Need help decoding 70 Cuda broadcast sheet [Re: 70gtx440dana] #1943977
11/02/15 10:33 PM
11/02/15 10:33 PM
Alabama
Alabama
Shaker code would have been on line 9 on the far right under the N codes .
That piece of the sheet is missing .
Greg
Re: Need help decoding 70 Cuda broadcast sheet [Re: Alaskan_TA] #1943982
11/02/15 10:42 PM
11/02/15 10:42 PM
Iowa
ratroaster Offline
ratroaster  Offline
Iowa
Barry, I think you are mistaken. This is an E series sheet which the code for N96 would be on line 9 toward the right end which is missing. The 6 on line 10 is an S code in the suspension and steering section. I don't think there is any other way to verify N96 unless you have the fender tag or window sticker.
Re: Need help decoding 70 Cuda broadcast sheet [Re: 70gtx440dana] #1943984
11/02/15 10:43 PM
11/02/15 10:43 PM
Alabama
Alabama
Also it appears a few of the codes are not in their "correct" boxes .
Greg
Re: Need help decoding 70 Cuda broadcast sheet [Re: BigMoneyLewis] #1944009
11/02/15 11:17 PM
11/02/15 11:17 PM
Iowa
ratroaster Offline
ratroaster  Offline
Iowa
Something fishy about this Broadcast sheet. I'm finding more codes that don't add up. More to look at yet.
Re: Need help decoding 70 Cuda broadcast sheet [Re: 70gtx440dana] #1944018
11/02/15 11:23 PM
11/02/15 11:23 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
I stand by what I said, but here is more information.
The sheet shown is an E-series (1969 model year).
But it has F Series codes (1970 model year) printed on it.
Not all of the box / option locations from one to the other are the same.
So, you have to align the codes with a 1970 model year sheet to decipher it.
The 'old' sheets were used up in the trim shop where the seats were done. All they needed was the interior trim code & model type which did not change positions, so it was a great way to use up leftover stock. It is actually pretty common to find the E series sheets in the seats of 1970 F series Hamtramck cars.
Re: Need help decoding 70 Cuda broadcast sheet [Re: 70gtx440dana] #1944025
11/02/15 11:29 PM
11/02/15 11:29 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
A close up from the same sheet from my files, note the year & series;
Re: Need help decoding 70 Cuda broadcast sheet [Re: Alaskan_TA] #1944036
11/02/15 11:39 PM
11/02/15 11:39 PM
Iowa
ratroaster Offline
ratroaster  Offline
Iowa
Ok, well that would explain all the confusion on the codes that don't match up. Thanks!
Re: Need help decoding 70 Cuda broadcast sheet [Re: 70gtx440dana] #1944046
11/02/15 11:45 PM
11/02/15 11:45 PM
Alabama
Alabama
Mmmm, very interesting . So those crazy cats down in the trim shop were printing out broadcast sheets on leftover E series paper..getting the codes all wonkey doo .
I learned something new today .
Greg
Re: Need help decoding 70 Cuda broadcast sheet [Re: BigMoneyLewis] #1944201
11/03/15 02:30 AM
11/03/15 02:30 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Greg
Yes. That's why I said you needed an F sheet to see where they should appear.
Re: Need help decoding 70 Cuda broadcast sheet [Re: 70gtx440dana] #1944236
11/03/15 03:37 AM
11/03/15 03:37 AM
Alabama
Alabama
I have plenty of E and F sheets over here (and G, and H) , I just didn't realize the Hamtramck trim dept printed off on the E series sheet , and certainly not well in to October . I learned something new .
Greg
Re: Need help decoding 70 Cuda broadcast sheet [Re: BigMoneyLewis] #1944554
11/03/15 08:50 PM
11/03/15 08:50 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
If you get lucky some vehicles have both series sheets hidden in them...Saves alot of decoding work...
