Need help decoding 70 Cuda broadcast sheet
#1943907
11/02/15 08:31 PM
11/02/15 08:31 PM
Posts: 3,524 Lansing, MI
70gtx440dana
Lansing, MI
Hoping some of our resident E body experts can provide decode info for this 70 Cuda broadcast sheet. Trying to help out a friend whom owns the car. This early sheet is a bit hard for me to understand as compared to the proper later 70 sheet. Also, this car is believed to be an original N96 shaker car. However this area of the sheet is missing. Are there any other clues on this sheet that would indicate it being a shaker car? Thanks in advance for any help!!!!
70 Road Runner 383-4 4 speed FJ5 & black guts 70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: Need help decoding 70 Cuda broadcast sheet
[Re: Alaskan_TA]
#1943937
11/02/15 09:25 PM
11/02/15 09:25 PM
Posts: 157 Detroit Michigan
1971HEMICUDA
Detroit Michigan
Line 10, see the six in the middle? N96- Shaker hood. Alaskan has it correct. That is a nicely optioned Cuda.
[Re: Alaskan_TA]
#1943970
11/02/15 10:20 PM
11/02/15 10:20 PM
70gtx440dana
Lansing, MI
Ahhhh....thanks for the info. Car has correct cable grommet in firewall so I was fairly certain it may be an N96 car. Car had some front end damage early on and now wears a rallye hood. I would appreciate any additional info. Things I know are:
440-6 auto FE5 red white interior auto with console Dana 60 am/fm radio
Really would like to know more about stripes, rear gear (think it's a 4.10 car), wheels & tires etc. I look forward to more replys.
[Re: Alaskan_TA]
#1943982
11/02/15 10:42 PM
11/02/15 10:42 PM
Posts: 318 Iowa
ratroaster
Iowa
Line 10, see the six in the middle? N96- Shaker hood. Barry, I think you are mistaken. This is an E series sheet which the code for N96 would be on line 9 toward the right end which is missing. The 6 on line 10 is an S code in the suspension and steering section. I don't think there is any other way to verify N96 unless you have the fender tag or window sticker.
[Re: BigMoneyLewis]
#1944009
11/02/15 11:17 PM
11/02/15 11:17 PM
Posts: 318 Iowa
ratroaster
Iowa
Also it appears a few of the codes are not in their "correct" boxes . Something fishy about this Broadcast sheet. I'm finding more codes that don't add up. More to look at yet.
[Re: BigMoneyLewis]
#1944201
11/03/15 02:30 AM
11/03/15 02:30 AM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
Mmmm, very interesting . So those crazy cats down in the trim shop were printing out broadcast sheets on leftover E series paper..getting the codes all wonkey doo . I learned something new today .
Greg Yes. That's why I said you needed an F sheet to see where they should appear.
