383-440 Rocker Arm shafts... #1942880
11/01/15 11:56 AM
11/01/15 11:56 AM
Jacksonville, FL
Chris2581 Offline OP
Jacksonville, FL
Who has the best product? I'm changing some of my engine combo and while apart,I wanted to upgrade the rocker shafts. I'm using Crane iron rockers.
Nautilus Racing-
Re: 383-440 Rocker Arm shafts... [Re: Chris2581] #1942914
11/01/15 12:33 PM
11/01/15 12:33 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
For shafts, I like the Harland Sharp setup. I had the early setup with the big jamb nuts, but the later ones use 12 point small diameter nuts. Much better fit. Come in 1.5 and 1.6 ratio's, and you can get your favorite offset to fit whatever heads you have.
[image][/image]
Re: 383-440 Rocker Arm shafts... [Re: Chris2581] #1942929
11/01/15 01:04 PM
11/01/15 01:04 PM
wellington ohio
68-scatpack-rt Offline
In thin ice
In thin ice
wellington ohio
Rocker arms unlimited.
Already banana grooved and made in the USA.
unions....the folks who brought you the weekend!
Re: 383-440 Rocker Arm shafts... [Re: Chris2581] #1942981
11/01/15 02:15 PM
11/01/15 02:15 PM
Kirkland, Washington
Pacnorthcuda Offline
I put my Crane irons on the shafts that Hughes Engines sells. They are harder than stock, thicker, banana grooved, and the end caps are threaded which means you can clean em out if you want.
I think they were about $150
Re: 383-440 Rocker Arm shafts... [Re: Chris2581] #1944502
11/03/15 06:49 PM
11/03/15 06:49 PM
Jacksonville, FL
Jacksonville, FL
After looking around and many calls,I went with Hughes parts.
Nautilus Racing-
