383-440 Rocker Arm shafts...
#1942880
11/01/15 11:56 AM
11/01/15 11:56 AM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
Who has the best product? I'm changing some of my engine combo and while apart,I wanted to upgrade the rocker shafts. I'm using Crane iron rockers.
Re: 383-440 Rocker Arm shafts...
[Re: Chris2581]
#1942914
11/01/15 12:33 PM
11/01/15 12:33 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
For shafts, I like the Harland Sharp setup. I had the early setup with the big jamb nuts, but the later ones use 12 point small diameter nuts. Much better fit. Come in 1.5 and 1.6 ratio's, and you can get your favorite offset to fit whatever heads you have.
[image][/image]
[Re: Chris2581]
#1942929
11/01/15 01:04 PM
11/01/15 01:04 PM
Posts: 1,144 wellington ohio
68-scatpack-rt
In thin ice
In thin ice
wellington ohio
Rocker arms unlimited. Already banana grooved and made in the USA.
unions....the folks who brought you the weekend!
[Re: Chris2581]
#1944502
11/03/15 06:49 PM
11/03/15 06:49 PM
Chris2581
Jacksonville, FL
After looking around and many calls,I went with Hughes parts.
