What gray paint or coating for exhaust manifolds? #1942078
10/31/15 12:37 PM
10/31/15 12:37 PM
US
f2502011 Offline OP
f2502011  Offline OP
US
1970 Challenger T/A. The exhaust manifolds were redone some time back with a gray coating of some kind. I screwed the finish up on one and need to redo them. Is there a good paint or coating I should use to do this?
1970 EK2 T/A 727
Re: What gray paint or coating for exhaust manifolds? [Re: f2502011] #1942090
10/31/15 12:42 PM
10/31/15 12:42 PM
md
mopars4ever Online content
mopars4ever  Online Content
md
http://www.por15.com/FACTORY-MANIFOLD-GRAY_p_51.html
may be this.
BTW, I blasted mine clean and wiped them down with powdered graphite diluted with mineral spirits and it lasted for quite a while.
Re: What gray paint or coating for exhaust manifolds? [Re: f2502011] #1942091
10/31/15 12:42 PM
10/31/15 12:42 PM
MD
floyd Offline
floyd  Offline
MD
Or maybe Eastwood's manifold coating:
http://www.eastwood.com/factory-gray-hi-temp-coating.html
It's pretty easy to resurface with a wire wheel/brush and re-coat.
Re: What gray paint or coating for exhaust manifolds? [Re: f2502011] #1942142
10/31/15 01:18 PM
10/31/15 01:18 PM
MA
steve70 Offline
steve70  Offline
MA
I used the Eastwood's high temp aerosol spray coating on both my cars. I sandblasted the manifolds, wiped them down with acetone and put on 3 light coats as suggested in the directions. It's been about 4 years now and both cars look still look great. There's no sign of fading or rust.
1970 Challenger T/A 4 speed
Re: What gray paint or coating for exhaust manifolds? [Re: steve70] #1942169
10/31/15 01:46 PM
10/31/15 01:46 PM
US
f2502011 Offline OP
f2502011  Offline OP
US
Same as the one in the Eastwood link above? How many cans?
1970 EK2 T/A 727
Re: What gray paint or coating for exhaust manifolds? [Re: f2502011] #1942221
10/31/15 02:52 PM
10/31/15 02:52 PM
MA
steve70 Offline
steve70  Offline
MA
Yes...the spray can. 1 can will be enough for a pair of manifolds. I believe 3 light coats is what they recommend.
Re: What gray paint or coating for exhaust manifolds? [Re: steve70] #1942877
11/01/15 11:50 AM
11/01/15 11:50 AM
MD
floyd Offline
floyd  Offline
MD
I've had good results touching up manifolds on the car with a foam brush. The colors evened up nicely after being heated.
Re: What gray paint or coating for exhaust manifolds? [Re: f2502011] #1942920
11/01/15 12:47 PM
11/01/15 12:47 PM
Banana Republic
FM3AAR Offline
FM3AAR  Offline
Banana Republic
I used the cast gray Bill Hirsch Hi-Temp exhaust manifold paint and was very happy with how they turned out. You can either brush it on or air gun it on, it's thin enough for that. In my case, I brushed it on and it came out nice. Per instructions, I baked them at 400 degrees for an hour, turned out nice. Just pick a time your wife will be away for the day, lol.
“You’ll own nothing” — And “you’ll be happy about it.”
K. Schwab
Re: What gray paint or coating for exhaust manifolds? [Re: f2502011] #1943291
11/01/15 10:51 PM
11/01/15 10:51 PM
htpd437
htpd437
I've used VHT Nu-cast high temp spray paint with good results.
Re: What gray paint or coating for exhaust manifolds? [Re: f2502011] #1944479
11/03/15 05:47 PM
11/03/15 05:47 PM
BlueRacer69 Offline
BlueRacer69  Offline
Me too. Eastwood high temp gray, Painted on with a brush.
Re: What gray paint or coating for exhaust manifolds? [Re: f2502011] #1945125
11/04/15 06:16 PM
11/04/15 06:16 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
The coating looks very neat but the original manifolds were not gray but were painted with the engine color. The paint burnt off and they should be natural cast iron...which is not gray. I just sand blasted mine and left them natural. Over the last 10 years, there is almost no surface rust but I don't drive it.
Re: What gray paint or coating for exhaust manifolds? [Re: f2502011] #1945223
11/04/15 08:41 PM
11/04/15 08:41 PM
htpd437
htpd437
Thats why I used the Nu Cast paint. Looks like fresh cast iron metal.
Re: What gray paint or coating for exhaust manifolds? [Re: f2502011] #1945797
11/05/15 06:39 PM
11/05/15 06:39 PM
WNY
slimert Offline
slimert  Offline
WNY
I've used the POR-15 manifold gray with nice results on my son's car.
Mike
Re: What gray paint or coating for exhaust manifolds? [Re: f2502011] #1945809
11/05/15 07:08 PM
11/05/15 07:08 PM
South Dakota
hotairballoonpilot Offline
South Dakota
eastwoods. I burned the front half of my 72 duster up with the manifolds painted with that stuff. Everything was burnt but after pressure washing it all off they looked like i just had done them while everything else was fried!
corey
Contact Me about AMD Prices
Re: What gray paint or coating for exhaust manifolds? [Re: hotairballoonpilot] #1946110
11/06/15 03:22 AM
11/06/15 03:22 AM
DE
Ply72rr Offline
Ply72rr  Offline
DE
There was an article in Mopar Enthusiast where they coated the exhaust manifolds with Slip Plate which is a graphite dry film lubricant. I have never tried it but they said it looked like bare cast iron, protected the manifolds, and was easy to touch up if needed.
Re: What gray paint or coating for exhaust manifolds? [Re: steve70] #1946120
11/06/15 04:01 AM
11/06/15 04:01 AM
Detroit
Kidsixpack Offline
Kidsixpack  Offline
Detroit
I've had really good resulst with the Eastwood stuff. Although I've never used the aerosol.
KID
Re: What gray paint or coating for exhaust manifolds? [Re: f2502011] #1946389
11/06/15 04:42 PM
11/06/15 04:42 PM
Kentucky
fc7freak Offline
fc7freak  Offline
Kentucky
I have used the Slip Plate on two different sets of manifolds. I like it!
Re: What gray paint or coating for exhaust manifolds? [Re: f2502011] #1946476
11/06/15 06:40 PM
11/06/15 06:40 PM
md
md
I made my own with dry graphite and mineral spirits. I suggested it but nobody seemed to catch it. It works but it is messy. It looks much better then painted manifolds which I think looks crappy and fake looking. Slip Plate seems to be a better alternative fhough.
Re: What gray paint or coating for exhaust manifolds? [Re: f2502011] #1947802
11/08/15 11:58 PM
11/08/15 11:58 PM
Southeast PA
5wndwcpe Offline
5wndwcpe  Offline
Southeast PA
I just did the Slip Plate application on my '57 a few weeks ago. It doesn't have much run time yet, but looks good and definitely does not look like paint.
1968 GTX hardtop
1968 Sport Satellite Convertible 383/4spd
1933 Plymouth coupe
2002 Ram 2500 oil burner 4x4
2015 Grand Cherokee
2013 Challenger
1957 Chrysler Saratoga
Man...I need a bigger freakin' garage.
Re: What gray paint or coating for exhaust manifolds? [Re: 5wndwcpe] #1954554
11/19/15 10:41 PM
11/19/15 10:41 PM
La Habra, CA
70440SIXPK Offline
70440SIXPK  Offline
La Habra, CA
I opted to sandblast the manifolds and use vht high temp cast... Paint works great! As a precautionary measure I heated the manifolds with a torch to "burn" the paint in.. Bolted them to the engine and painted the entire engine so it would have the correct orange burnt look without the rust BS... Came out great!
1970 Challenger
Factory V Code
