What gray paint or coating for exhaust manifolds?
#1942078
10/31/15 12:37 PM
10/31/15 12:37 PM
Posts: 364 US
f2502011
US
1970 Challenger T/A. The exhaust manifolds were redone some time back with a gray coating of some kind. I screwed the finish up on one and need to redo them. Is there a good paint or coating I should use to do this?
1970 EK2 T/A 727
Re: What gray paint or coating for exhaust manifolds?
[Re: f2502011]
#1942142
10/31/15 01:18 PM
10/31/15 01:18 PM
Posts: 892 MA
steve70
MA
I used the Eastwood's high temp aerosol spray coating on both my cars. I sandblasted the manifolds, wiped them down with acetone and put on 3 light coats as suggested in the directions. It's been about 4 years now and both cars look still look great. There's no sign of fading or rust.
1970 Challenger T/A 4 speed
[Re: steve70]
#1942169
10/31/15 01:46 PM
10/31/15 01:46 PM
Posts: 364 US
f2502011
US
I used the Eastwood's high temp aerosol spray coating on both my cars. I sandblasted the manifolds, wiped them down with acetone and put on 3 light coats as suggested in the directions. It's been about 4 years now and both cars look still look great. There's no sign of fading or rust. Same as the one in the Eastwood link above? How many cans?
1970 EK2 T/A 727
[Re: f2502011]
#1942221
10/31/15 02:52 PM
10/31/15 02:52 PM
Posts: 892 MA
steve70
MA
I used the Eastwood's high temp aerosol spray coating on both my cars. I sandblasted the manifolds, wiped them down with acetone and put on 3 light coats as suggested in the directions. It's been about 4 years now and both cars look still look great. There's no sign of fading or rust. Same as the one in the Eastwood link above? How many cans? Yes...the spray can. 1 can will be enough for a pair of manifolds. I believe 3 light coats is what they recommend.
[Re: f2502011]
#1942920
11/01/15 12:47 PM
11/01/15 12:47 PM
Posts: 2,348 Banana Republic
FM3AAR
Banana Republic
I used the cast gray Bill Hirsch Hi-Temp exhaust manifold paint and was very happy with how they turned out. You can either brush it on or air gun it on, it's thin enough for that. In my case, I brushed it on and it came out nice. Per instructions, I baked them at 400 degrees for an hour, turned out nice. Just pick a time your wife will be away for the day, lol.
“You’ll own nothing” — And “you’ll be happy about it.” K. Schwab
[Re: f2502011]
#1943291
11/01/15 10:51 PM
11/01/15 10:51 PM
htpd437
htpd437
I've used VHT Nu-cast high temp spray paint with good results.
[Re: f2502011]
#1945125
11/04/15 06:16 PM
11/04/15 06:16 PM
Posts: 5,123 Warrenton, VA
RoadRunnerJD
Warrenton, VA
The coating looks very neat but the original manifolds were not gray but were painted with the engine color. The paint burnt off and they should be natural cast iron...which is not gray. I just sand blasted mine and left them natural. Over the last 10 years, there is almost no surface rust but I don't drive it.
[Re: f2502011]
#1945223
11/04/15 08:41 PM
11/04/15 08:41 PM
htpd437
htpd437
Thats why I used the Nu Cast paint. Looks like fresh cast iron metal.
[Re: f2502011]
#1945809
11/05/15 07:08 PM
11/05/15 07:08 PM
Posts: 5,668 South Dakota
hotairballoonpilot
South Dakota
eastwoods. I burned the front half of my 72 duster up with the manifolds painted with that stuff. Everything was burnt but after pressure washing it all off they looked like i just had done them while everything else was fried!
corey
Contact Me about AMD Prices
[Re: f2502011]
#1946476
11/06/15 06:40 PM
11/06/15 06:40 PM
Posts: 13,600 md
mopars4ever
md
There was an article in Mopar Enthusiast where they coated the exhaust manifolds with Slip Plate which is a graphite dry film lubricant. I have never tried it but they said it looked like bare cast iron, protected the manifolds, and was easy to touch up if needed. I made my own with dry graphite and mineral spirits. I suggested it but nobody seemed to catch it. It works but it is messy. It looks much better then painted manifolds which I think looks crappy and fake looking. Slip Plate seems to be a better alternative fhough.
[Re: f2502011]
#1947802
11/08/15 11:58 PM
11/08/15 11:58 PM
Posts: 1,528 Southeast PA
5wndwcpe
Southeast PA
I just did the Slip Plate application on my '57 a few weeks ago. It doesn't have much run time yet, but looks good and definitely does not look like paint.
1968 GTX hardtop 1968 Sport Satellite Convertible 383/4spd 1933 Plymouth coupe 2002 Ram 2500 oil burner 4x4 2015 Grand Cherokee 2013 Challenger 1957 Chrysler Saratoga
Man...I need a bigger freakin' garage.
[Re: 5wndwcpe]
#1954554
11/19/15 10:41 PM
11/19/15 10:41 PM
Posts: 183 La Habra, CA
70440SIXPK
La Habra, CA
I opted to sandblast the manifolds and use vht high temp cast... Paint works great! As a precautionary measure I heated the manifolds with a torch to "burn" the paint in.. Bolted them to the engine and painted the entire engine so it would have the correct orange burnt look without the rust BS... Came out great!
1970 Challenger Factory V Code
