popping out the exhaust #1940995
10/29/15 01:22 PM
10/29/15 01:22 PM
Newark, OH
Hunted Duck Offline OP
Newark, OH
Getting a popping sound out of the passenger side exhaust. Number 8 ex. rocker was loose. Bent valve is my guess. Anything else it could be?
Re: popping out the exhaust [Re: Hunted Duck] #1941009
10/29/15 01:56 PM
10/29/15 01:56 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Broken valve spring will do that too...
Re: popping out the exhaust [Re: Hunted Duck] #1941035
10/29/15 02:38 PM
10/29/15 02:38 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
It could be fuel burning in the pipe and the cold air rushing back in.
Re: popping out the exhaust [Re: Clanton] #1941073
10/29/15 03:52 PM
10/29/15 03:52 PM
Addison,IL
OUTLAWSSAA Online content
OUTLAWSSAA  Online Content
Addison,IL
If its popping when you let off at the big end, it could be a bad header gasket.
Re: popping out the exhaust [Re: Hunted Duck] #1941889
10/31/15 12:01 AM
10/31/15 12:01 AM
Newark, OH
Newark, OH
The popping was at idle. When i reved it up it sounded like it was gone.No popping when i left off on the top end.
Re: popping out the exhaust [Re: Hunted Duck] #1941896
10/31/15 12:05 AM
10/31/15 12:05 AM
pacific northwest
Stroker Scamp Offline
pacific northwest
When I had a same issue it was too fat, fuel re igniting in the
exhaust
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: popping out the exhaust [Re: Hunted Duck] #1942040
10/31/15 11:05 AM
10/31/15 11:05 AM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
camshaft going flat if its not a roller
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: popping out the exhaust [Re: Hunted Duck] #1942058
10/31/15 11:39 AM
10/31/15 11:39 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
i had the same issue with the 408. when i pulled the heads all exhaust valves had been hitting the pistons. the springs got weak and they had over .200" to piston clearance. i'm thinking you may have an exhaust valve or valves not seating.
Re: popping out the exhaust [Re: Hunted Duck] #1946511
11/06/15 07:21 PM
11/06/15 07:21 PM
Newark, OH
Newark, OH
The valve springs are probably week. Seat checked 210 not sure open pressure. Its a roller. Springs have been on the motor since 2008. 700+ runs. Maybe more.
Re: popping out the exhaust [Re: Hunted Duck] #1947013
11/07/15 04:45 PM
11/07/15 04:45 PM
River Falls, WI
urdustd Offline
urdustd  Offline
River Falls, WI
I had a similar issue, popping out the exhaust only at idle. Bring up the RPM's and it went away. I checked the ignition pulled carb apart, adjusted valves, checked for intake and exhaust leaks nothing worked. In the end..bad gas. Emptied the tank, cleaned it and put in new fuel and it ran like a champ. Gas of today isn't anywhere near as stable as fuel even from a few years back. Something else for you to consider.
Re: popping out the exhaust [Re: Hunted Duck] #1947324
11/08/15 01:05 AM
11/08/15 01:05 AM
Newark, OH
Newark, OH
I'm going to get the motor out this week but im starting to think it a bad roller lifter.
