Stock iron Hemi heads flow potential #1939250
10/26/15 10:09 PM
10/26/15 10:09 PM
fredericksburg,va
cudaman1969 Offline OP
fredericksburg,va
Putting together a Hemi and need some discussion time. 4.5 stroke 4.31 bore 68 block 66 heads. I've read that the intakes ports will flow enough with the extra cubes, but the exhaust look they might not. Is this right and if so what improvements if any can be done to them? Older super stock cam about .700 lift
Re: Stock iron Hemi heads flow potential [Re: cudaman1969] #1939282
10/26/15 10:40 PM
10/26/15 10:40 PM
Ohio
shorthorse Offline
shorthorse  Offline
Ohio
Re: Stock iron Hemi heads flow potential [Re: shorthorse] #1939350
10/26/15 11:46 PM
10/26/15 11:46 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Typically they flow 350-370cfm out of the box even with mild porting....They can flow up to or around 420cfm with someone who is really good like Ray Barton, but I have not seen a set flow that much in cast iron in a while. Above that is usually Stage V territory...
My latest aluminum set flowed 457cfm at .700.....
Re: Stock iron Hemi heads flow potential [Re: Dragula] #1939389
10/27/15 12:37 AM
10/27/15 12:37 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Block will need some work to clear a 4.5 stroke.This is a megablock with 4.5 arm.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Stock iron Hemi heads flow potential [Re: cudaman1969] #1939525
10/27/15 10:52 AM
10/27/15 10:52 AM
tennessee,usa
mattsmopars Offline
mattsmopars  Offline
tennessee,usa
I know curiosity killed the cat , but does your 68 block have a partial vin stamp on it? It should be back by the oil pressure switch on the flange where the bellhousing would bolt up.
Thanks Matt
Re: Stock iron Hemi heads flow potential [Re: mattsmopars] #1939617
10/27/15 12:56 PM
10/27/15 12:56 PM
fredericksburg,va
fredericksburg,va
Thanks Matt
Never crossed my mind but I will look.
Re: Stock iron Hemi heads flow potential [Re: hemi-itis] #1939622
10/27/15 12:59 PM
10/27/15 12:59 PM
fredericksburg,va
fredericksburg,va
Already checked that, rods on the crank clear, will check again by the oil boss. BBC size
No telling how many times this block has been through the wash. "Rumors" it's an ex Bob Reed engine last.
Re: Stock iron Hemi heads flow potential [Re: Dragula] #1939625
10/27/15 01:02 PM
10/27/15 01:02 PM
fredericksburg,va
fredericksburg,va
Is those numbers intake or ex.
Re: Stock iron Hemi heads flow potential [Re: cudaman1969] #1939638
10/27/15 01:28 PM
10/27/15 01:28 PM
an8sec70cuda Offline
If I'm not mistaken, my MP aluminum hemi heads are basically just aluminum versions of the factory iron heads.
MCH cnc ported them and they flow 429.5 cfm intake and 283 cfm exhaust w/ a tube.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Stock iron Hemi heads flow potential [Re: an8sec70cuda] #1939652
10/27/15 01:47 PM
10/27/15 01:47 PM
fredericksburg,va
fredericksburg,va
What size engine, and if you don't mind telling, some particulars. Tying to get some comparisons. Kinda what works and not.
My dad, family, lives in Bishopville, how close are you? Any tracks beside Darlington? They want me to move down with them.
Re: Stock iron Hemi heads flow potential [Re: cudaman1969] #1939656
10/27/15 01:50 PM
10/27/15 01:50 PM
572, 11:1 for pump gas, 276/284 at fifty mild lobe street roller, single dominator, etc.
9.50s at 140 mph on the motor, 8.95 so far on a plate system at 3900 lbs.
CHIP
Re: Stock iron Hemi heads flow potential [Re: cudaman1969] #1939669
10/27/15 02:30 PM
10/27/15 02:30 PM
tennessee,usa
mattsmopars Offline
mattsmopars  Offline
tennessee,usa
Thanks Matt
That would be great if you could do that and post it. Might be someone's original engine.
Matt
Re: Stock iron Hemi heads flow potential [Re: cudaman1969] #1939823
10/27/15 07:34 PM
10/27/15 07:34 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
Does it have BULLET stamped in by the distributor? I have a Hemi block that I got from Jim Hale years ago, and I believe he got it when he bought the old Banning & Slaughter Hemi Cuda. My understanding is that Tommy Slaughter traded parts with Bullet Bob. I called Bob on it years ago and he said he thought it sounded like one of his old blocks.
Floyd Lippencott IV
Re: Stock iron Hemi heads flow potential [Re: cudaman1969] #1939825
10/27/15 07:40 PM
10/27/15 07:40 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
Flow data on MCH regular CNC porting on Hemi heads. Jeff had a SS Hemi port that flowed more than this, but cost a bunch more too. I think Jeff improved on these numbers somewhat a couple of years ago after he did my iron MP heads. FYI.
Floyd Lippencott IV
Re: Stock iron Hemi heads flow potential [Re: an8sec70cuda] #1939935
10/27/15 10:08 PM
10/27/15 10:08 PM
Dragula Offline
Dragula  Offline
Correct...flows the same as Cast Iron 350-370cfm
Intake numbers
Exhaust numbers
Re: Stock iron Hemi heads flow potential [Re: Dragula] #1940068
10/28/15 01:23 AM
10/28/15 01:23 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
I have a set of 1968 Iron castings, ported by the late Glenn Knowlton. These heads were done for Chuck Lofgrens entry into the Royal Purple Hemi Challenge, and his engine won. After the contest, the engine was parted out and I bought them and put them on my FAST motor. They flow 420 intake 325 exhaust. They are for sale.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Stock iron Hemi heads flow potential [Re: cudaman1969] #1940074
10/28/15 01:30 AM
10/28/15 01:30 AM
State of Fascism
52savoy Online content
52savoy  Online Content
State of Fascism
So what is the vin on the backside.. us '68 Hemi owners gotta know.
Re: Stock iron Hemi heads flow potential [Re: 52savoy] #1940090
10/28/15 02:00 AM
10/28/15 02:00 AM
fredericksburg,va
fredericksburg,va
Numbers I found. Next to oil sending hole- 3 3 8 3 8 0 7 first 3-8 can't tell for sure but does have round tops like 3-8
Oil pan rail at back next to bell- stamped 42624570006 -Maltese emblem. above that 4-16-68 ,block casting date 1-15-68
Front pan rail at timing cover the name WARFEL
Re: Stock iron Hemi heads flow potential [Re: mr_340] #1940091
10/28/15 02:02 AM
10/28/15 02:02 AM
fredericksburg,va
fredericksburg,va
Nothing there, ground off a lot, bottom pan rail at timing cover the name WARFEL
Re: Stock iron Hemi heads flow potential [Re: cudaman1969] #1940108
10/28/15 02:54 AM
10/28/15 02:54 AM
DFW
mr_340 Offline
mr_340  Offline
DFW
Glenn Warfel, Scat Pack Dodge Dart. Look down a bit to see the copper colored Dart.
http://classracer.com/classforum/showthread.php?t=13002&page=288
Floyd Lippencott IV
