Re: Wierd Electrical Problem
[Re: jeebis44]
#1939346
10/26/15 11:43 PM
10/26/15 11:43 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Don't see how a bad starter relay would kill power to the entire car.
[Re: stumpy]
#1939357
10/26/15 11:54 PM
10/26/15 11:54 PM
Posts: 1,528 Southeast PA
5wndwcpe
Southeast PA
Battery cables loose or dirty on one end or the other. Check the cables at the starter relay and starter also. ... and the ground(s).
1968 GTX hardtop 1968 Sport Satellite Convertible 383/4spd 1933 Plymouth coupe 2002 Ram 2500 oil burner 4x4 2015 Grand Cherokee 2013 Challenger 1957 Chrysler Saratoga
Man...I need a bigger freakin' garage.
[Re: NANKET]
#1939436
10/27/15 02:07 AM
10/27/15 02:07 AM
RapidRobert
What Nanket said & if good in that large cable system then next time it goes dead see if you have fire at the alt "batt" stud & you might seperate/check/clean the bulkhead and check the ammeter terminals in that path. For it to be completely dead there would need to be an open between the batt positive post to/thru the bulkhead & to/thru the ammeter to the "welded splice". Bulkhead/ammeter are culprits & with it going completely open/dead you'll easily see it (poor/loose connection/terminal) with some checking
[Re: Andrewh]
#1939756
10/27/15 05:22 PM
10/27/15 05:22 PM
Posts: 1,018 Here and now
jeebis44
Here and now
Thanks for the help guys - long story short it was a bad ground. The Block/Body cable had corroded in half! Replaced that and cleaned up the battery/block connection and all is well again.
