Wierd Electrical Problem #1939294
10/26/15 10:55 PM
10/26/15 10:55 PM
Here and now
jeebis44 Offline OP
jeebis44  Offline OP
Here and now
Stock '66 Chrysler 300 w/ 383 4bbl. When I turn the key to start the engine, it makes a click and the whole car loses power. Disconnect battery and reconnect, car has power. Try to crank and same thing happens. Have tried 2 different batteries, one of them brand new. No luck
Any ideas?
Re: Wierd Electrical Problem [Re: jeebis44] #1939312
10/26/15 11:07 PM
10/26/15 11:07 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Battery cables loose or dirty on one end or the other. Check the cables at the starter relay and starter also.
Re: Wierd Electrical Problem [Re: jeebis44] #1939324
10/26/15 11:21 PM
10/26/15 11:21 PM
WA
tman Offline
tman  Offline
WA
How is the Battery itself?
Re: Wierd Electrical Problem [Re: jeebis44] #1939330
10/26/15 11:27 PM
10/26/15 11:27 PM
Here and now
jeebis44 Offline OP
jeebis44  Offline OP
Here and now
Batteries are fully charged - work fine in my '66 Fury III
Re: Wierd Electrical Problem [Re: jeebis44] #1939333
10/26/15 11:28 PM
10/26/15 11:28 PM
Here and now
jeebis44 Offline OP
jeebis44  Offline OP
Here and now
All connections are clean and snug. Could it be a bad starter relay?
Re: Wierd Electrical Problem [Re: jeebis44] #1939346
10/26/15 11:43 PM
10/26/15 11:43 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Don't see how a bad starter relay would kill power to the entire car.
Don't be the exception.
Re: Wierd Electrical Problem [Re: stumpy] #1939357
10/26/15 11:54 PM
10/26/15 11:54 PM
Southeast PA
5wndwcpe Offline
5wndwcpe  Offline
Southeast PA
... and the ground(s).
1968 GTX hardtop
1968 Sport Satellite Convertible 383/4spd
1933 Plymouth coupe
2002 Ram 2500 oil burner 4x4
2015 Grand Cherokee
2013 Challenger
1957 Chrysler Saratoga
Man...I need a bigger freakin' garage.
Re: Wierd Electrical Problem [Re: 5wndwcpe] #1939366
10/27/15 12:11 AM
10/27/15 12:11 AM
Here and now
jeebis44 Offline OP
jeebis44  Offline OP
Here and now
Will check all grounds in the morning. It is very strange how disconnecting then reconnecting the battery restores power to the car.
Re: Wierd Electrical Problem [Re: jeebis44] #1939385
10/27/15 12:34 AM
10/27/15 12:34 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
That is where the problem is, in the connections at the battery terminals, or where you are flexing the cables moving them to changing the batteries.
Re: Wierd Electrical Problem [Re: NANKET] #1939436
10/27/15 02:07 AM
10/27/15 02:07 AM
What Nanket said & if good in that large cable system then next time it goes dead see if you have fire at the alt "batt" stud & you might seperate/check/clean the bulkhead and check the ammeter terminals in that path. For it to be completely dead there would need to be an open between the batt positive post to/thru the bulkhead & to/thru the ammeter to the "welded splice". Bulkhead/ammeter are culprits & with it going completely open/dead you'll easily see it (poor/loose connection/terminal) with some checking
Re: Wierd Electrical Problem [Re: jeebis44] #1939454
10/27/15 03:12 AM
10/27/15 03:12 AM
WA
tman Offline
tman  Offline
WA
If the battery cables are old, sometimes they turn into that nasty green stuff or corrosion under the insulation. They look good from the outside, but look like crap inside. Someone posted something similar, but changed out all his battery cables and all was good.
Re: Wierd Electrical Problem [Re: jeebis44] #1939509
10/27/15 10:24 AM
10/27/15 10:24 AM
Andrewh Offline
Andrewh  Offline
I agree. I have had a bad ground cable do something similar.
it wouldn't start at all.
crushing the cable by bending it 90 degrees at the block got it running again, but I swapped it out and all was good after that.
you can prove it to yourself by running a new seperate ground to the block and checking your lights come back without disconnecting the battery.
use a good large gauge wire if you have it.
Re: Wierd Electrical Problem [Re: Andrewh] #1939756
10/27/15 05:22 PM
10/27/15 05:22 PM
Here and now
jeebis44 Offline OP
jeebis44  Offline OP
Here and now
Thanks for the help guys - long story short it was a bad ground. The Block/Body cable had corroded in half! Replaced that and cleaned up the battery/block connection and all is well again.
