brakes 71 rr
#1938532
10/25/15 09:10 PM
10/25/15 09:10 PM
Posts: 202 Altoona, Pa.
71runnerm51
Altoona, Pa.
replaced all lines, wheel cylinders and shoes Had good brakes.got a master cylinder now have good pedal sitting bad pedal on the road .. any ideas.all drum manual brakes
Re: brakes 71 rr
[Re: 71runnerm51]
#1938568
10/25/15 09:59 PM
10/25/15 09:59 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
replaced all lines, wheel cylinders and shoes Had good brakes.got a master cylinder now have good pedal sitting bad pedal on the road .. any ideas.all drum manual brakes when you say good pedal, bad pedal are you referring to the actual pedal travel or good pedal feel sitting and no stopping when you go?
Re: brakes 71 rr
[Re: 71runnerm51]
#1938615
10/25/15 11:01 PM
10/25/15 11:01 PM
71runnerm51
Altoona, Pa.
good or full pedal just sitting ..on a ride the pedal almost to the floor
