brakes 71 rr #1938532
10/25/15 09:10 PM
10/25/15 09:10 PM
Altoona, Pa.
71runnerm51 Offline OP
Altoona, Pa.
replaced all lines, wheel cylinders and shoes Had good brakes.got a master cylinder now have good pedal sitting bad pedal on the road .. any ideas.all drum manual brakes
Re: brakes 71 rr [Re: 71runnerm51] #1938568
10/25/15 09:59 PM
10/25/15 09:59 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
when you say good pedal, bad pedal are you referring to the actual pedal travel or good pedal feel sitting and no stopping when you go?
Re: brakes 71 rr [Re: 71runnerm51] #1938615
10/25/15 11:01 PM
10/25/15 11:01 PM
Altoona, Pa.
Altoona, Pa.
good or full pedal just sitting ..on a ride the pedal almost to the floor
Re: brakes 71 rr [Re: 71runnerm51] #1938617
10/25/15 11:05 PM
10/25/15 11:05 PM
Altoona, Pa.
Altoona, Pa.
good pedal just sitting ..on a ride the pedal almost to the floor. yes pedal travel
Re: brakes 71 rr [Re: 71runnerm51] #1938618
10/25/15 11:07 PM
10/25/15 11:07 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
How's the brake adjustments? Very important, esp on drum brakes on 4 corners of that car.
Re: brakes 71 rr [Re: 71runnerm51] #1938632
10/25/15 11:28 PM
10/25/15 11:28 PM
Altoona, Pa.
Altoona, Pa.
rookie on adjusting ...will you get good brake pedal sitting but bad brake pedal while moving with bad adjustment?
Re: brakes 71 rr [Re: 71runnerm51] #1938641
10/25/15 11:39 PM
10/25/15 11:39 PM
chicagoland,usa
chicagoland,usa
Well, normally the loose adjustment scenario will have pedal come up after a few pumps of pedal, then stay high-solid. Next time you first apply brakes, it may be low again. Wondering if you have a master issue...
Re: brakes 71 rr [Re: buildanother] #1938657
10/26/15 12:01 AM
10/26/15 12:01 AM
Altoona, Pa.
Altoona, Pa.
I just replaced the master cylinder,will check the adjustment Monday
Re: brakes 71 rr [Re: 71runnerm51] #1939245
10/26/15 10:05 PM
10/26/15 10:05 PM
Altoona, Pa.
Altoona, Pa.
problem solved had one brake shoe that wasn't adjusted properly boogie
