E body 500" carb fuel tank #1938524
10/25/15 08:58 PM
10/25/15 08:58 PM
Oh Canada
E
EV2CUDA Offline OP
EV2CUDA  Offline OP
E
Oh Canada
I don't want to cut the floor or use a cell in the trunk. Looking for ideas to cleanly install an electric pump setup.
71 Barracuda 383 4spd (500ci)
69 camaro 598, NOS
69 barracuda bbc procharger
77 t/a 6.0 turbo project
78 t/a 400
77 corvette
1983 hurst/olds
03 Viper
79 360 macho
71 demon 360
78 Warlock 5.7 hemi project
Re: E body 500" carb fuel tank [Re: EV2CUDA] #1938540
10/25/15 09:18 PM
10/25/15 09:18 PM
AndyF Offline
AndyF  Offline
Use a modern design pump that mounts inside the tank.
Re: E body 500" carb fuel tank [Re: EV2CUDA] #1938607
10/25/15 10:45 PM
10/25/15 10:45 PM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
I have a small sump welded to the original fuel tank with 2x -10 fittings at the rear feeding 2x Carter pumps on the left side of the tank, 528 cube Barracuda.
1963 Plymouth Max Wedge
1971 Barracuda
Re: E body 500" carb fuel tank [Re: EV2CUDA] #1938786
10/26/15 07:53 AM
10/26/15 07:53 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
I'm using a Magnafuel 275 & a 1/2"pickup that incorporates an extra line that I hook the return on my line from the pump to. The bracket is connected to the underside of my bolt in cage.
Re: E body 500" carb fuel tank [Re: EV2CUDA] #1938991
10/26/15 03:57 PM
10/26/15 03:57 PM
Oh Canada
E
EV2CUDA Offline OP
EV2CUDA  Offline OP
E
Oh Canada
I have a 3" tail pipe right there so space is limited but that is the idea if the space was there.
Will a intank pump work with a carb since most are designed for efi.
69 camaro 598, NOS
78 t/a 400
77 corvette
1983 hurst/olds
03 Viper
79 360 macho
71 demon 360
Re: E body 500" carb fuel tank [Re: EV2CUDA] #1939024
10/26/15 04:55 PM
10/26/15 04:55 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
that is exactly what im doing on my 68 cuda......
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: E body 500" carb fuel tank [Re: EV2CUDA] #1939030
10/26/15 05:11 PM
10/26/15 05:11 PM
AndyF Offline
AndyF  Offline
An intake pump works fine with a carb but you'll need a return line. That is actually the best system for a carb but it does involve running the second line back to the tank. The return line setup always has fresh gas at the carb so it gets rid of the fuel line boiling issue on hot days or other such problems.
You should be able to buy a brand new tank for an E body that is already set up for an intank pump. So it is almost a plug and play type of deal these days.
Re: E body 500" carb fuel tank [Re: Old School] #1939051
10/26/15 05:53 PM
10/26/15 05:53 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
Mine is installed in a cell, but using a 255 Walbro reg'd to 6psi for my 493. Amp draw is ~5 amps at 6-7psi. Pickup sock is a cheap pre-filter.
Only challenge might be baffles in a stock tank, check out Aeromotive Phantom or Tanks Inc for some aftermarket options.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: E body 500" carb fuel tank [Re: EV2CUDA] #1939176
10/26/15 09:04 PM
10/26/15 09:04 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
you could always make a bracket & mount the pump in front of the tank & up behind the diff.
Re: E body 500" carb fuel tank [Re: EV2CUDA] #1939274
10/26/15 10:33 PM
10/26/15 10:33 PM
tulsa ok
U
upnover Offline
upnover  Offline
U
tulsa ok
i have a 512 in my 72 cuda and it has the stock tank with a 1/2" line through the factory pickup(sending unit doesent work)and the pump is mounted on a bracket that hangs just below the tank on the passenger side. no issues running mid tens so far
Re: E body 500" carb fuel tank [Re: EV2CUDA] #1939336
10/26/15 11:32 PM
10/26/15 11:32 PM
southern Maryland
K
keefe Offline
keefe  Offline
K
southern Maryland
This site might help.
http://www.tanksinc.com/index.cfm/page/p...prod/prd477.htm
1971 duster twister 440, 3380#,509 M/P hyd,906's,full Exhaust,11.06@117.46 1/4,6.95@ 97.03 1/8,1.497 60ft.....
Re: E body 500" carb fuel tank [Re: EV2CUDA] #1939347
10/26/15 11:45 PM
10/26/15 11:45 PM
southern Maryland
K
keefe Offline
keefe  Offline
K
southern Maryland
Re: E body 500" carb fuel tank [Re: EV2CUDA] #1939460
10/27/15 03:46 AM
10/27/15 03:46 AM
Outside
thedriver Offline
thedriver  Offline
Outside
I bought a comp engineering sump and trimmed it down and tigged it to the new tank. Looks cool. If I knew how to post a pic I would! Lol
1973 challenger
Dana. 4 speed. Low deck.
Re: E body 500" carb fuel tank [Re: EV2CUDA] #1939537
10/27/15 11:00 AM
10/27/15 11:00 AM
an8sec70cuda Offline
I have a stock tank w/ a sump welded on. Aeromotive A1000 pump mounted to the inside of the pass. frame rail. Probably won't work w/ tailpipes. -10 feed, -8 return...the return goes into the factory 3/8" sending unit p/u tube.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: E body 500" carb fuel tank [Re: an8sec70cuda] #1940013
10/27/15 11:55 PM
10/27/15 11:55 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Re: E body 500" carb fuel tank [Re: EV2CUDA] #1940589
10/28/15 07:37 PM
10/28/15 07:37 PM
Oh Canada
E
EV2CUDA Offline OP
EV2CUDA  Offline OP
E
Oh Canada
That's a nice tank setup but I don't want to disturb trunk area.
The weld on sump or tanks inc unit looks to be the winner.
69 camaro 598, NOS
78 t/a 400
77 corvette
1983 hurst/olds
03 Viper
79 360 macho
71 demon 360
