E body 500" carb fuel tank
#1938524
10/25/15 08:58 PM
10/25/15 08:58 PM
Posts: 738 Oh Canada
EV2CUDA
Oh Canada
I don't want to cut the floor or use a cell in the trunk. Looking for ideas to cleanly install an electric pump setup.
71 Barracuda 383 4spd (500ci) 69 camaro 598, NOS 69 barracuda bbc procharger 77 t/a 6.0 turbo project 78 t/a 400 77 corvette 1983 hurst/olds 03 Viper 79 360 macho 71 demon 360 78 Warlock 5.7 hemi project
Re: E body 500" carb fuel tank
[Re: EV2CUDA]
#1938607
10/25/15 10:45 PM
10/25/15 10:45 PM
Posts: 1,096 Australia
ozymaxwedge
Australia
I have a small sump welded to the original fuel tank with 2x -10 fittings at the rear feeding 2x Carter pumps on the left side of the tank, 528 cube Barracuda.
1963 Plymouth Max Wedge 1971 Barracuda
[Re: EV2CUDA]
#1938991
10/26/15 03:57 PM
10/26/15 03:57 PM
EV2CUDA
Oh Canada
I have a 3" tail pipe right there so space is limited but that is the idea if the space was there. Will a intank pump work with a carb since most are designed for efi.
[Re: EV2CUDA]
#1939024
10/26/15 04:55 PM
10/26/15 04:55 PM
Posts: 1,169 Virginia Beach, VA
Old School
Virginia Beach, VA
I have a 3" tail pipe right there so space is limited but that is the idea if the space was there. Will a intank pump work with a carb since most are designed for efi. that is exactly what im doing on my 68 cuda......
68 cuda formula S 588" bb 5sp 70 CUDA CONVERT 500" 5SP (SUBLIME) 70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
[Re: Old School]
#1939051
10/26/15 05:53 PM
10/26/15 05:53 PM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
Mine is installed in a cell, but using a 255 Walbro reg'd to 6psi for my 493. Amp draw is ~5 amps at 6-7psi. Pickup sock is a cheap pre-filter.
Only challenge might be baffles in a stock tank, check out Aeromotive Phantom or Tanks Inc for some aftermarket options.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: EV2CUDA]
#1939176
10/26/15 09:04 PM
10/26/15 09:04 PM
Posts: 4,647 aotearoa
rebel
aotearoa
I have a 3" tail pipe right there so space is limited but that is the idea if the space was there. you could always make a bracket & mount the pump in front of the tank & up behind the diff.
[Re: EV2CUDA]
#1939460
10/27/15 03:46 AM
10/27/15 03:46 AM
Posts: 1,481 Outside
thedriver
Outside
I bought a comp engineering sump and trimmed it down and tigged it to the new tank. Looks cool. If I knew how to post a pic I would! Lol
1973 challenger Dana. 4 speed. Low deck.
[Re: EV2CUDA]
#1939537
10/27/15 11:00 AM
10/27/15 11:00 AM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
I have a stock tank w/ a sump welded on. Aeromotive A1000 pump mounted to the inside of the pass. frame rail. Probably won't work w/ tailpipes. -10 feed, -8 return...the return goes into the factory 3/8" sending unit p/u tube.
[Re: EV2CUDA]
#1940589
10/28/15 07:37 PM
10/28/15 07:37 PM
EV2CUDA
Oh Canada
That's a nice tank setup but I don't want to disturb trunk area. The weld on sump or tanks inc unit looks to be the winner.
