Disc brakes #1937777
10/24/15 03:15 PM
10/24/15 03:15 PM
Eastern ohio
Alexdodge Offline OP
Eastern ohio
Is it necessary to go from 14 to 15 inch wheels to put disc brakes on a 62 dodge polara?
Re: Disc brakes [Re: Alexdodge] #1937857
10/24/15 06:35 PM
10/24/15 06:35 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Depends on what brakes you use. Some with the smaller rotor will clear 14's.
Re: Disc brakes [Re: Alexdodge] #1937863
10/24/15 06:42 PM
10/24/15 06:42 PM
None
71rm23 Offline
71rm23  Offline
None
I'd say no
Re: Disc brakes [Re: Alexdodge] #1937870
10/24/15 06:57 PM
10/24/15 06:57 PM
Andrewh Offline
Andrewh  Offline
no. if you use the 10 inch discs off an m-body, it clears the 14 inch wheels just fine.
I used them for a while till I swapped out to 15 inch rims and then up to the 11 inch disc's.
65 coronet, so same body basically.
Re: Disc brakes [Re: Alexdodge] #1937905
10/24/15 07:44 PM
10/24/15 07:44 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
The small discs are 10.87" in diameter and fit most 14" rims.
The large discs are 11.75" in diameter and will not fit a 14" rim.
Speaking of factory discs only.
Don't be the exception.
Re: Disc brakes [Re: Andrewh] #1937920
10/24/15 08:14 PM
10/24/15 08:14 PM
None
71rm23 Offline
71rm23  Offline
None
Forgot. Must be getting Alszheimers. Should've asked or the OP stated what size discs he's using
Re: Disc brakes [Re: 71rm23] #1937925
10/24/15 08:19 PM
10/24/15 08:19 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Ya gotta remember that not all 14's are the same...some are disc brake spec and some not.
