Re: Disc brakes
[Re: Alexdodge]
#1937857
10/24/15 06:35 PM
10/24/15 06:35 PM
Posts: 25,791 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Depends on what brakes you use. Some with the smaller rotor will clear 14's.
Re: Disc brakes
[Re: Alexdodge]
#1937905
10/24/15 07:44 PM
10/24/15 07:44 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
The small discs are 10.87" in diameter and fit most 14" rims.
The large discs are 11.75" in diameter and will not fit a 14" rim.
Speaking of factory discs only.
Re: Disc brakes
[Re: Andrewh]
#1937920
10/24/15 08:14 PM
10/24/15 08:14 PM
Posts: 2,592 None
71rm23
None
no. if you use the 10 inch discs off an m-body, it clears the 14 inch wheels just fine. I used them for a while till I swapped out to 15 inch rims and then up to the 11 inch disc's. 65 coronet, so same body basically. Forgot. Must be getting Alszheimers. Should've asked or the OP stated what size discs he's using
Re: Disc brakes
[Re: 71rm23]
#1937925
10/24/15 08:19 PM
10/24/15 08:19 PM
John_Kunkel
Rio Linda, CA
Ya gotta remember that not all 14's are the same...some are disc brake spec and some not.
