Does the dash need to come out for heater box #1933642
10/17/15 02:14 AM
10/17/15 02:14 AM
minnarusta
TX9H6E4CUDA Offline OP
minnarusta
On my 1971 Charger, does the dash need to come out to remove the heater box? I wanna restore the box, heater core, and evaporator. My car has A/C also.
For the absolute best powder coating go to J.I.T powder coating, contact infomation is in my personal profile..
Re: Does the dash need to come out for heater box [Re: TX9H6E4CUDA] #1933683
10/17/15 09:57 AM
10/17/15 09:57 AM
Manitoba, Canada
Big Wedge Offline
Big Wedge  Offline
Manitoba, Canada
It shouldn't. I have done a 68 dart and 70 Challenger. There are not that many fasteners holding it in. If my memory serves me correct, there are the nuts on the heater motor on the firewall (engine compartment side) and a long "J" style rod through the passenger's vent. Once the box is lowered a little bit, the cables and electrical can be disconnected.
Garth
Re: Does the dash need to come out for heater box [Re: TX9H6E4CUDA] #1933709
10/17/15 11:16 AM
10/17/15 11:16 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Nope the dash doesn't need to come out on your 71
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Does the dash need to come out for heater box [Re: TX9H6E4CUDA] #1933993
10/17/15 11:21 PM
10/17/15 11:21 PM
New Mexico, USA
attaboy Offline
attaboy  Offline
New Mexico, USA
No, the dash doesn't need to come out but it's a pain getting everything out from under it, especially if you have with A/C. I had to remove one of the vac valves to get it out completely and then reinstall. Be mindful of the vac tubing connections and routing. Be very careful of the plastic [censored] on the control valve and connector(they're brittle). Console has to come out, so does the radio, glove box, and most of the passenger ductwork. It can be done but it does take some real effort.
attaboy
Re: Does the dash need to come out for heater box [Re: TX9H6E4CUDA] #1934850
10/19/15 12:09 PM
10/19/15 12:09 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Yes you can get it out with the dash in the car. But your back is going to hate when its done
