Re: Carb for a 400??
[Re: Thor500]
#1932617
10/15/15 02:25 PM
10/15/15 02:25 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
400's have no compression, throw in a big cam and a big carb and you don't have "good street manners" especially if it's an auto. BTDT.
Comparing a high performance, high compression, big cam 396 to a emissions choked, low compression 400 is not useful unless you plan to build the 400 up to similar compression, cam and THEN carb specs then maybe it's relevant.
[Re: Thor500]
#1932908
10/15/15 11:41 PM
10/15/15 11:41 PM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
8867 ? Where is that part number located ?
Give us the number on the front bottom/base , left side
1407 / 1411 /1406 etc
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: Thor500]
#1933038
10/16/15 02:34 AM
10/16/15 02:34 AM
RapidRobert
Looking for good street manners. Are you have a driveability issue right now or does it need rebuilding? Does the CFM of it seem just right or too much? What SCR do you have? I did have an eddy 1406 (600 CFM) on a 350 horse 440 in a C boat DD (came that way). was fine but was a DD. Eddys CAN have probs with a low vac signal (wild cam).
