69 Road Runnner Correct Hood and Trunk Latch Colors #1662918
08/24/14 03:31 AM
08/24/14 03:31 AM
Arizona
69rrgrabber Offline OP
Arizona
Hello Folks,
About to do some plating but not sure on the factory finishes as they were already blasted bare metal when I bought the car. This is a 69 Road Runner and I'm hoping to find the correct finishes for the:
Hood latch:
Hood striker:
Hood release lever:
Trunk latch:
Trunk striker:
My research has not revealed much as I have access to no original cars.
Thanks,
Carl
"It takes a Mopar to catch a Mopar!" 1969 Charger R/T 440 1969 Road Runner 383 1970 Cuda 440
Re: 69 Road Runnner Correct Hood and Trunk Latch Colors [Re: 69rrgrabber] #1662919
08/24/14 11:40 AM
08/24/14 11:40 AM
Canada
ACR2000 Offline
ACR2000  Offline
Canada
Hi Carl, finish on the hood hook and catch/release should be brown zinc. Hood striker are black phosphate and then are painted the color of the car. Pop up spring are also black phosphate.
The trunk realated mechanism are all clear zinc finish. I think the trunk striker might have been in some case also painted the color of the car.
Join is a set I restored for a E Body.
Re: 69 Road Runnner Correct Hood and Trunk Latch Colors [Re: ACR2000] #1662920
08/24/14 11:45 AM
08/24/14 11:45 AM
Canada
ACR2000 Offline
ACR2000  Offline
Canada
Here's another pic comparing NOS vs my restored brown zinc finishes.
Re: 69 Road Runnner Correct Hood and Trunk Latch Colors [Re: ACR2000] #1662921
08/24/14 12:57 PM
08/24/14 12:57 PM
Az
69hemibeep Offline
69hemibeep  Offline
Az
I'm not sure about the other plants but Lynch Rd the trunk striker got painted
1969 Hemi Roadrunner 2nd owner
Re: 69 Road Runnner Correct Hood and Trunk Latch Colors [Re: 69hemibeep] #1662922
08/24/14 05:25 PM
08/24/14 05:25 PM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
I agree. On Plymouth both the trunk and hood strikers were painted body color.
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: 69 Road Runnner Correct Hood and Trunk Latch Colors [Re: MOPARMIKE69] #1662923
08/24/14 08:04 PM
08/24/14 08:04 PM
Arizona
Arizona
Holy smoke, those pictures are great, thanks so much! I like the idea of zinc plating the strikers and then paining, that way they wont rust as the paint wears from the striker.
The only thing I am still not sure about is the hood release lever that unlocks the hood latch, its different then the big hook that attaches to the hood, should it be zinc or brown?
THanks,
Carl
Re: 69 Road Runnner Correct Hood and Trunk Latch Colors [Re: 69rrgrabber] #1662924
08/24/14 08:29 PM
08/24/14 08:29 PM
Canada
ACR2000 Offline
ACR2000  Offline
Canada
THanks,
Carl
Brown also
This one is for a E Body
Re: 69 Road Runnner Correct Hood and Trunk Latch Colors [Re: ACR2000] #1931493
10/13/15 04:29 PM
10/13/15 04:29 PM
Dallas, Texas
FC7cuda Offline
FC7cuda  Offline
Dallas, Texas
Are the bolts that hold the release lever and the safety lever brown zinc also or black phosphate?
Tom
68 Charger
70 Cuda
Re: 69 Road Runnner Correct Hood and Trunk Latch Colors [Re: FC7cuda] #1931604
10/13/15 08:07 PM
10/13/15 08:07 PM
Canada
ACR2000 Offline
ACR2000  Offline
Canada
Hi Tom,
Bolts are black phosphate
Stephan
Re: 69 Road Runnner Correct Hood and Trunk Latch Colors [Re: ACR2000] #1931942
10/14/15 12:04 PM
10/14/15 12:04 PM
Bradford, Ontario
Barrelhouse Offline
Barrelhouse  Offline
Bradford, Ontario
My 72 Demon complete hood latch set up was restored by Stephan his work is top notch if you want perfection get him do do it.
Re: 69 Road Runnner Correct Hood and Trunk Latch Colors [Re: 69rrgrabber] #1932128
10/14/15 05:28 PM
10/14/15 05:28 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
The trunk latch needs to be disassembled to be plated properly. Otherwise the part that the key rod goes through could get destroyed in the process
Re: 69 Road Runnner Correct Hood and Trunk Latch Colors [Re: Morty426] #1932337
10/14/15 11:17 PM
10/14/15 11:17 PM
Canada
ACR2000 Offline
ACR2000  Offline
Canada
Exactly... And the spring needs to be black
