Re: Got a 70s Kingpin Dana 60, now what?
[Re: Brad4406]
#1930855
10/12/15 02:22 PM
10/12/15 02:22 PM
Posts: 5,924 ohio
ruderunner
ohio
Last question first, yes locking hubs bolt on. I got Milemarkers from summit.
You will need a set of shims to get the pinion pointed at the t case. And then you need to cut the welds holding the knuckles on and rotate them for correct caster.
Search for " cut and turn" Binderplanet.com has some good write-ups.
Angry white pureblood male
[Re: Brad4406]
#1931410
10/13/15 02:25 PM
10/13/15 02:25 PM
Posts: 5,924 ohio
ruderunner
ohio
Iits harder to get all the weld out that hold the tubes to the center section. And you still need to shim the center for pinion angle. Most will grind out the welds that hold the knuckles to the tubes. Then the knuckles can be beat into position with a hammer and rewelded. I hope you're not thinking of actually cutting the tubes. Major problems with strength and alignment will result.
Yep that's a 75-90 kingpin axle with external lockouts. The 91-93 trucks had different lockouts.
[Re: 67R/T4speeder]
#1931656
10/13/15 09:37 PM
10/13/15 09:37 PM
Posts: 70 Lebanon, OH
Brad4406
Lebanon, OH
Your hub look like this with out the lock part? I've attached a pic of what it looks like.
[Re: ruderunner]
#1931657
10/13/15 09:38 PM
10/13/15 09:38 PM
Brad4406
Lebanon, OH
I hope you're not thinking of actually cutting the tubes. Major problems with strength and alignment will result. I was until I read the posts on the site you directed me to.
[Re: Brad4406]
#1931937
10/14/15 11:40 AM
10/14/15 11:40 AM
Posts: 1,669 Caldwell, Idaho
67R/T4speeder
Caldwell, Idaho
Your hub look like this with out the lock part? I've attached a pic of what it looks like. Nice !! You got the good one
[Re: Brad4406]
#1934563
10/18/15 11:48 PM
10/18/15 11:48 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Tom Woods custom drivelines will answer some of your questions, I have run his shafts for years. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: 440_Offroader]
#1935851
10/20/15 10:38 PM
10/20/15 10:38 PM
Brad4406
Lebanon, OH
Another option for your pinion angle... have a driveshaft built with 1350 CVs on both ends. I had this done for my 79 Macho with full time four wheel drive. I only have a few thousand miles on it, but seems to be holding up fine. Just a way of not having to worry about cutting,welding,caster angles, etc. I never considered that. Does it require a pinion yoke change?
[Re: astjp2]
#1936328
10/21/15 08:18 PM
10/21/15 08:18 PM
Brad4406
Lebanon, OH
Tom Woods custom drivelines will answer some of your questions, I have run his shafts for years. Tim Thanks for the info.
[Re: Brad4406]
#1938172
10/25/15 08:15 AM
10/25/15 08:15 AM
Posts: 5,924 ohio
ruderunner
ohio
I liked mine, easy to use in mud a snow, especially with gloves. Keep the mounting bolts tight or better yet go with studs and nuts.
[Re: Brad4406]
#1939749
10/27/15 05:05 PM
10/27/15 05:05 PM
67R/T4speeder
Caldwell, Idaho
Those look like selectro hubs. How do you like them? Like ruderunner said "easy to use" when your hands are all sloppy muddy and cold. Always work for me, even the original 1/2 ton set off this truck I put on wifes Ramcharger and still going strong. I keep a set of those full time gears in tool box just in case I am out and I DID break one.
[Re: ruderunner]
#1939751
10/27/15 05:07 PM
10/27/15 05:07 PM
67R/T4speeder
Caldwell, Idaho
I liked mine, easy to use in mud a snow, especially with gloves. Keep the mounting bolts tight or better yet go with studs and nuts. Good idea with the studs, I might do that. Toyota comes stock that way with cone washers.
[Re: Brad4406]
#1940359
10/28/15 02:28 PM
10/28/15 02:28 PM
Posts: 5,924 ohio
ruderunner
ohio
Yeah the only problem I ever had with the old selectros was I blew one apart when the bolts came loose.
