BOM numbers on a 72 B body Dana 60 housing #1928664
10/08/15 10:35 PM
10/08/15 10:35 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
I went to look at a dana 60 rear end yesterday and took my list of BOM numbers from two websites. They listed the rear end as a 70-72 B body. Of course we all know that a 71-72 b body is a different cat than a 70. Of coarse they listed a 69 e body as well. The numbers are 603222-2 with a date code of 5-13-2. Looks like a rare piece to me. My question is what website has the correct info? The ones I have found do not even list a 71-72 b body housing.
Re: BOM numbers on a 72 B body Dana 60 housing [Re: fastmark] #1930934
10/12/15 04:51 PM
10/12/15 04:51 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
This should help.
Re: BOM numbers on a 72 B body Dana 60 housing [Re: 6PakBee] #1931203
10/13/15 12:41 AM
10/13/15 12:41 AM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
That is the same wrong info that I already have. A 69 and 70 rear end for a b body is different than a 71-72. Ask dr dif. My Spicer chart listed 69 e body rear. They don't make those either.
Re: BOM numbers on a 72 B body Dana 60 housing [Re: fastmark] #1931264
10/13/15 07:59 AM
10/13/15 07:59 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Well, that is a scan from a Dana publication. If it's wrong then Dana made the error.
Re: BOM numbers on a 72 B body Dana 60 housing [Re: fastmark] #1931421
10/13/15 02:41 PM
10/13/15 02:41 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
Yes. You are correct. I've seen the same published info on several sites. They are all wrong. I was hoping someone had the correct info.
Re: BOM numbers on a 72 B body Dana 60 housing [Re: fastmark] #1931643
10/13/15 09:03 PM
10/13/15 09:03 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
Obviously Spicer has it wrong & most likely Dr.diff has it all figured out & will hopefully chime in & set the recorded straight,you could also measure the rear & figure it out.
Re: BOM numbers on a 72 B body Dana 60 housing [Re: 71GTX471] #1931958
10/14/15 12:36 PM
10/14/15 12:36 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
Dr. diff does have it figured out. I knew what it was by the date code and not the BOM numbers. It just happened to have been restored and sold by him ten years ago. It had Quality bodyshop and drivetrain on the box with no address!
Re: BOM numbers on a 72 B body Dana 60 housing [Re: fastmark] #1932036
10/14/15 03:08 PM
10/14/15 03:08 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I believe this is correct.
Re: BOM numbers on a 72 B body Dana 60 housing [Re: John_Kunkel] #1932111
10/14/15 04:55 PM
10/14/15 04:55 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
This is the 3.54 DANA 60 from a largely correct/intact 60K mile '72 GTX (St. Louis, Dec. 1971 assembled), date codes for the whole car are all over the place.
Anyone know what part number would be on the paper tag?
Re: BOM numbers on a 72 B body Dana 60 housing [Re: fastmark] #1932215
10/14/15 08:20 PM
10/14/15 08:20 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
John Ks list still shows a 69 E body,could you really get a 4.56 or 5.38 gear.
FastM I forgot you had the date code there.
Re: BOM numbers on a 72 B body Dana 60 housing [Re: fastmark] #1932367
10/15/15 12:04 AM
10/15/15 12:04 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
That list is still incorrect, but I think the low gears and later date codes designate over-the-counter Dana 60 rearend assemblies sold by Direct Connection.
Re: BOM numbers on a 72 B body Dana 60 housing [Re: DoctorDiff] #1934337
10/18/15 04:13 PM
10/18/15 04:13 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
If both are incorrect do you or anyone know what is and where it might be found??? beer
Re: BOM numbers on a 72 B body Dana 60 housing [Re: fastmark] #1935235
10/19/15 10:24 PM
10/19/15 10:24 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
The list is only a guide @ this time & not gospel if you don't pick up on the already outlined minor mistakes I guess it could mess you up,print one out & make the corrections.
Re: BOM numbers on a 72 B body Dana 60 housing [Re: fastmark] #1936743
10/22/15 03:16 PM
10/22/15 03:16 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Air shocks! That is definitely period correct.
2011 Drag Pak Challenger
