Motorhome 440 cam recomendation #1930412
10/11/15 09:06 PM
10/11/15 09:06 PM
Tulsa oklahoma USA
2
2734bbl Offline OP
2734bbl  Offline OP
Tulsa oklahoma USA
I just purchased a 39,000 mile motor to replace the motor I broke a rod bolt in.
It's a good running piece but I would like install a small cam before I install it in the car. I have a RPM intake, headers, 3500 vert and 3.91 gears.
My question is there a cam I can install without having to change the valve springs to bump up the output?
Re: Motorhome 440 cam recomendation [Re: 2734bbl] #1930418
10/11/15 09:28 PM
10/11/15 09:28 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
You might get away with the summit K6401.
Re: Motorhome 440 cam recomendation [Re: DaytonaTurbo] #1930465
10/11/15 10:21 PM
10/11/15 10:21 PM
IN
ahy Offline
ahy  Offline
IN
If you are concerned about the stock springs (I would be) you might find a very good deal on a set of "take off" springs from an Edelbrock RPM or Stealth head... where the customer wanted a different spring. They can handle a lot more cam vs lo po originals. Worth a call to Hughes, Muscle Motors and others to ask.
Re: Motorhome 440 cam recomendation [Re: 2734bbl] #1930569
10/12/15 12:53 AM
10/12/15 12:53 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I'd really consider a set of springs, cheap insurance and better performance. As for a cam, short duration & about 112 LC will help mask the low CR; lift will help it breathe & make power, and I'd look for at least .480, as much as .510.
Re: Motorhome 440 cam recomendation [Re: topside] #1930756
10/12/15 11:52 AM
10/12/15 11:52 AM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
X2.
Re: Motorhome 440 cam recomendation [Re: 2734bbl] #1931077
10/12/15 09:42 PM
10/12/15 09:42 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
Re: Motorhome 440 cam recomendation [Re: 2734bbl] #1931212
10/13/15 12:58 AM
10/13/15 12:58 AM
Tulsa oklahoma USA
2
2734bbl Offline OP
2734bbl  Offline OP
Tulsa oklahoma USA
Thanks for the replies.
I did find a guy local to me that has the tool I can borrow so that opens up the possibilities some.
Im looking to use a Hughes Whiplash cam kit.
Re: Motorhome 440 cam recomendation [Re: 2734bbl] #1933418
10/16/15 08:24 PM
10/16/15 08:24 PM
Manitoba, Canada
Manitoba, Canada
Too aggressive for stock springs IMO.
Re: Motorhome 440 cam recomendation [Re: 2734bbl] #1934220
10/18/15 12:32 PM
10/18/15 12:32 PM
Tulsa oklahoma USA
2
2734bbl Offline OP
2734bbl  Offline OP
Tulsa oklahoma USA
yea, I spoke with them Thursday. They have a complete kit with cam, lifters and springs for $339.
I think this will be the way I go. This as a cast crank engine with 452 heads and it all looks pretty good other than I need to get some keepers for the new exhaust springs.
