Motorhome 440 cam recomendation
#1930412
10/11/15 09:06 PM
10/11/15 09:06 PM
Posts: 155 Tulsa oklahoma USA
2734bbl
Tulsa oklahoma USA
I just purchased a 39,000 mile motor to replace the motor I broke a rod bolt in.
It's a good running piece but I would like install a small cam before I install it in the car. I have a RPM intake, headers, 3500 vert and 3.91 gears.
My question is there a cam I can install without having to change the valve springs to bump up the output?
Re: Motorhome 440 cam recomendation
[Re: topside]
#1930756
10/12/15 11:52 AM
10/12/15 11:52 AM
Posts: 5,387 Pikes Peak Country
TC@HP2
Pikes Peak Country
I'd really consider a set of springs, cheap insurance and better performance. As for a cam, short duration & about 112 LC will help mask the low CR; lift will help it breathe & make power, and I'd look for at least .480, as much as .510. X2.
[Re: 2734bbl]
#1931212
10/13/15 12:58 AM
10/13/15 12:58 AM
2734bbl
Tulsa oklahoma USA
Thanks for the replies.
I did find a guy local to me that has the tool I can borrow so that opens up the possibilities some.
Im looking to use a Hughes Whiplash cam kit.
[Re: 2734bbl]
#1933418
10/16/15 08:24 PM
10/16/15 08:24 PM
DaytonaTurbo
Manitoba, Canada
Im looking to use a Hughes Whiplash cam kit. Too aggressive for stock springs IMO.
