M.P. 402 Crate Help - Harmonic Balancer & Pulleys #1929608
10/10/15 02:13 PM
10/10/15 02:13 PM
challconv70 Offline OP
Hi, I am trying to kill 2 birds with one stone, I have a 402 crate engine that has a vibration (rpm specific but worse in 4th gear) as well as some belt alignment problems, so I am intending to buy a harmonic balancer and pulley set first before I tear into the engine or pull the trans. My struggle is trying to figure out which harmonic balancer to buy and which pulley kit. There isn't a lot of information out there on this engine. I think the pulley kit should be a standard magnum engine but wanted to see if anyone has any info or good links that could help me verify the right harmonic balancer.
Re: M.P. 402 Crate Help - Harmonic Balancer & Pulleys [Re: challconv70] #1929872
10/10/15 10:52 PM
10/10/15 10:52 PM
dogdays Offline
dogdays  Offline
Unless you KNOW something is wrong with the harmonic damper I'd say LEAVE IT ALONE!
Who's to say how it was balanced when it was built?
R.
