Exhaust manifold stud install #1926641
10/05/15 11:13 PM
10/05/15 11:13 PM
KS
68SportSatvert Offline OP
KS
What is the best way to install new exhaust manifold studs and do I need to put any kind of sealant on them? I want to make sure I get them in right the first time with no leaks. Thanks in advance!
Re: Exhaust manifold stud install [Re: 68SportSatvert] #1926676
10/05/15 11:47 PM
10/05/15 11:47 PM
moparx Offline
moparx  Offline
i have always "double nutted" them[jamming two nuts together on the non head side threada to tighten them into the head thread].teflon paste is my preferred sealant.
beer
Re: Exhaust manifold stud install [Re: moparx] #1926721
10/06/15 12:32 AM
10/06/15 12:32 AM
use some thick viscous cement such as Permatex #1 or #2 in the toothpaste like tube & as said double nut it with (2) fine thread nuts to lock it in there
Re: Exhaust manifold stud install [Re: 68SportSatvert] #1926904
10/06/15 11:03 AM
10/06/15 11:03 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I put Indian head gasket shellac on them , screw them in by double nutting and let it cure.
Re: Exhaust manifold stud install [Re: 68SportSatvert] #1927110
10/06/15 03:49 PM
10/06/15 03:49 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I double nut them in place but don't need to use sealant.
- Stu Harmon
Re: Exhaust manifold stud install [Re: 68SportSatvert] #1927278
10/06/15 08:34 PM
10/06/15 08:34 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Depends on the head in question and if it's a blind hole or open to the cooling jacket.
If it's open, sealant is ok. If it's a blind hole you could potentially hydraulic the steup and crack the casting.
So, open sealant ok
Blind, no sealant.
Don't be the exception.
Re: Exhaust manifold stud install [Re: Supercuda] #1927351
10/06/15 10:27 PM
10/06/15 10:27 PM
OE BB's I believe all of em are wet. OE Sb's only the (4) corner holes are wet
Re: Exhaust manifold stud install [Re: 68SportSatvert] #1927360
10/06/15 10:38 PM
10/06/15 10:38 PM
KS
KS
Thanks guys! It is for a 383.
Re: Exhaust manifold stud install [Re: 68SportSatvert] #1927625
10/07/15 11:43 AM
10/07/15 11:43 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
But what heads ?
If they are not factory heads, iron or stage 6 style, they may not be wet and sealer won't be needed ...
Re: Exhaust manifold stud install [Re: 68SportSatvert] #1929346
10/09/15 11:15 PM
10/09/15 11:15 PM
KS
KS
The heads are stock 906s
Re: Exhaust manifold stud install [Re: 68SportSatvert] #1929432
10/10/15 02:35 AM
10/10/15 02:35 AM
all wet/brake kleen studs/holes/use thick sealer
Re: Exhaust manifold stud install [Re: 68SportSatvert] #1929613
10/10/15 02:26 PM
10/10/15 02:26 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I'd use the Indian Head sealer. Double nut to install.
