Re: Exhaust manifold stud install
[Re: moparx]
#1926721
10/06/15 12:32 AM
10/06/15 12:32 AM
RapidRobert
use some thick viscous cement such as Permatex #1 or #2 in the toothpaste like tube & as said double nut it with (2) fine thread nuts to lock it in there
[Re: 68SportSatvert]
#1926904
10/06/15 11:03 AM
10/06/15 11:03 AM
Posts: 74,978 U.S.S.A.
JohnRR
U.S.S.A.
I put Indian head gasket shellac on them , screw them in by double nutting and let it cure.
#1927110
10/06/15 03:49 PM
10/06/15 03:49 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I double nut them in place but don't need to use sealant.
#1927278
10/06/15 08:34 PM
10/06/15 08:34 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
What is the best way to install new exhaust manifold studs and do I need to put any kind of sealant on them? I want to make sure I get them in right the first time with no leaks. Thanks in advance! Depends on the head in question and if it's a blind hole or open to the cooling jacket. If it's open, sealant is ok. If it's a blind hole you could potentially hydraulic the steup and crack the casting. So, open sealant ok Blind, no sealant.
[Re: Supercuda]
#1927351
10/06/15 10:27 PM
10/06/15 10:27 PM
RapidRobert
OE BB's I believe all of em are wet. OE Sb's only the (4) corner holes are wet
#1927625
10/07/15 11:43 AM
10/07/15 11:43 AM
JohnRR
U.S.S.A.
Thanks guys! It is for a 383. But what heads ? If they are not factory heads, iron or stage 6 style, they may not be wet and sealer won't be needed ...
#1929432
10/10/15 02:35 AM
10/10/15 02:35 AM
RapidRobert
all wet/brake kleen studs/holes/use thick sealer
