1250 dominator too much for my motor? #1928934
10/09/15 11:50 AM
10/09/15 11:50 AM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
Found an add for a used 1250 cfm dominator carb here in sweden.
I wonder if it will be way too much for my r5p7 motor.
Re: 1250 dominator too much for my motor? [Re: sshemi] #1928971
10/09/15 12:50 PM
10/09/15 12:50 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
yes
Re: 1250 dominator too much for my motor? [Re: sshemi] #1928974
10/09/15 01:04 PM
10/09/15 01:04 PM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
Ok thanks
Re: 1250 dominator too much for my motor? [Re: sshemi] #1928977
10/09/15 01:07 PM
10/09/15 01:07 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I`d go w/a 2-circuit 1050 Dominator properly set up.......
Re: 1250 dominator too much for my motor? [Re: sshemi] #1928994
10/09/15 01:27 PM
10/09/15 01:27 PM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
For e85?
Re: 1250 dominator too much for my motor? [Re: sshemi] #1928997
10/09/15 01:30 PM
10/09/15 01:30 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Sure why not......
Re: 1250 dominator too much for my motor? [Re: sshemi] #1929004
10/09/15 01:39 PM
10/09/15 01:39 PM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
Ok im interested. Lets talk via pm or facebook?
Re: 1250 dominator too much for my motor? [Re: sshemi] #1929005
10/09/15 01:42 PM
10/09/15 01:42 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
way to big of carb
Re: 1250 dominator too much for my motor? [Re: sshemi] #1929007
10/09/15 01:47 PM
10/09/15 01:47 PM
AndyF Offline
AndyF  Offline
Quick rule of thumb is HP x 1.4 = CFM. So you need to be making about 900 hp before you need 1250 cfm.
Re: 1250 dominator too much for my motor? [Re: sshemi] #1929027
10/09/15 02:25 PM
10/09/15 02:25 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Never been a believer in "formulas" per say, because few of them EVER suggest a Dominator for a small block, yet 9 of 10 run faster with a Dominator............However, in this case the 1250 is WAY too big. Too much throttle blade size, will result in very low air speed. I agree that it needs a 1050
Re: 1250 dominator too much for my motor? [Re: sshemi] #1929037
10/09/15 02:33 PM
10/09/15 02:33 PM
Cab_Burge Online work
Cab_Burge  Online Work
Find out if that carb has straight boosters in it or if it has skirted boosters before buying it and converting it. If it has skirted booster then it is probally to big. I bought a Holley 1150 CFM Dominator and had it straight down boosters, I had it converted to E85 and it came back with skirted boosters so it flowed less( how much less I don't know confused) after the conversion work shruggy I tested that carb. on E85 on the same motor with a Holley 1050 Dominator on pump gas and the motor made 687 HP on pump gas with less torque than HP, the same motor 20 minutes later made 676 HP and 686 Ft. lbs of torque on E85 with that carb.shock confused My new bracket car has never ran any other fuel than E85 up
Re: 1250 dominator too much for my motor? [Re: sshemi] #1929050
10/09/15 02:53 PM
10/09/15 02:53 PM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
Thumperdart i read your post too fast. I read that you have a carb instead of that you suggest.
Re: 1250 dominator too much for my motor? [Re: sshemi] #1929054
10/09/15 02:55 PM
10/09/15 02:55 PM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
Cant see enough of boosters.
Re: 1250 dominator too much for my motor? [Re: sshemi] #1929080
10/09/15 03:17 PM
10/09/15 03:17 PM
Washington
madscientist Offline
Washington
Pay attention to what Monte said because it is very telling.
Monte didn't say 1250 CFM was too much (really because it's a piss poor way to rate a carb) but that the butterflies (throttle blades) are too big.
Chances are, the 1050 would flow more than that (1050) anyway.
I also agree that those formula are a joke. One of the smartest manifold engineers I ever had the pleasure of talking to way back in 1984 told me to ignore those things. He had a chart in his catalog that gave RPM/airflow/CFM but he said it was a very loose guide and generally was extremely conservative.
Re: 1250 dominator too much for my motor? [Re: sshemi] #1929111
10/09/15 03:55 PM
10/09/15 03:55 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I suggest a 1050 Dominator w/a good base tune instead of MOST of the stuff that`s shipped out w/too much emulsion and wrong set up for starters.......
Re: 1250 dominator too much for my motor? [Re: madscientist] #1929114
10/09/15 03:58 PM
10/09/15 03:58 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Totally agree about these formulas in general cos EVERY motor I put a bigger carb on runs better AND goes faster.......
Re: 1250 dominator too much for my motor? [Re: sshemi] #1929141
10/09/15 04:59 PM
10/09/15 04:59 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I agree those 1250 listed Holly carbs have way to big a throttle blade for most applications for folks on this board.
Re: 1250 dominator too much for my motor? [Re: sshemi] #1929599
10/10/15 01:43 PM
10/10/15 01:43 PM
Mark Whitener Offline
This is where it's a maybe, maybe not. How big is the engine? How heavy is the car? I have a 461 ci SB2 head engine, I've successfully made more power and quicker track times with a 1450, 2.25 throttle blade 2.050 venturi carb. Those heads are a spinoff of an SB2 head and with enough cubic inches, at least 400, the 1250 will be a good choice. Below that you better be spinning 9000 +.
Mark Whitener
[url=www.racingfuelsystems.com[/url]
Re: 1250 dominator too much for my motor? [Re: sshemi] #1929615
10/10/15 02:27 PM
10/10/15 02:27 PM
sweden
sshemi Offline OP
sshemi  Offline OP
sweden
Only 358cui.
Ill wait and save up some money and order a custom built carb for it.
Not sure the fuel pump can deliver enough on e85 though...
Re: 1250 dominator too much for my motor? [Re: AndyF] #1929759
10/10/15 07:47 PM
10/10/15 07:47 PM
eastern,Ky
70RT Charger Offline
eastern,Ky
Just how true is this? If it is I see ALOT of guys running way to big of a carb. 530 HP builds with 950 carbs. By that math figure it should be running a 750. If you used a 750 instead would you still have 530 HP?
