Re: 1250 dominator too much for my motor?
[Re: sshemi]
#1928974
10/09/15 01:04 PM
10/09/15 01:04 PM
Posts: 2,128 sweden
sshemi
sweden
[Re: sshemi]
#1928977
10/09/15 01:07 PM
10/09/15 01:07 PM
Thumperdart
State of confusion
I`d go w/a 2-circuit 1050 Dominator properly set up.......
[Re: sshemi]
#1928994
10/09/15 01:27 PM
10/09/15 01:27 PM
Posts: 2,128 sweden
sshemi
sweden
[Re: sshemi]
#1929080
10/09/15 03:17 PM
10/09/15 03:17 PM
Posts: 4,457 Washington
madscientist
Washington
Pay attention to what Monte said because it is very telling.
Monte didn't say 1250 CFM was too much (really because it's a piss poor way to rate a carb) but that the butterflies (throttle blades) are too big.
Chances are, the 1050 would flow more than that (1050) anyway.
I also agree that those formula are a joke. One of the smartest manifold engineers I ever had the pleasure of talking to way back in 1984 told me to ignore those things. He had a chart in his catalog that gave RPM/airflow/CFM but he said it was a very loose guide and generally was extremely conservative.
[Re: sshemi]
#1929111
10/09/15 03:55 PM
10/09/15 03:55 PM
Thumperdart
State of confusion
Thumperdart i read your post too fast. I read that you have a carb instead of that you suggest. I suggest a 1050 Dominator w/a good base tune instead of MOST of the stuff that`s shipped out w/too much emulsion and wrong set up for starters.......
[Re: madscientist]
#1929114
10/09/15 03:58 PM
10/09/15 03:58 PM
Thumperdart
State of confusion
I also agree that those formula are a joke. One of the smartest manifold engineers I ever had the pleasure of talking to way back in 1984 told me to ignore those things. He had a chart in his catalog that gave RPM/airflow/CFM but he said it was a very loose guide and generally was extremely conservative. Totally agree about these formulas in general cos EVERY motor I put a bigger carb on runs better AND goes faster.......
[Re: sshemi]
#1929141
10/09/15 04:59 PM
10/09/15 04:59 PM
Posts: 19,373 Las Vegas
Al_Alguire
Las Vegas
I agree those 1250 listed Holly carbs have way to big a throttle blade for most applications for folks on this board.
[Re: sshemi]
#1929599
10/10/15 01:43 PM
10/10/15 01:43 PM
Posts: 304 Florida
Mark Whitener
This is where it's a maybe, maybe not. How big is the engine? How heavy is the car? I have a 461 ci SB2 head engine, I've successfully made more power and quicker track times with a 1450, 2.25 throttle blade 2.050 venturi carb. Those heads are a spinoff of an SB2 head and with enough cubic inches, at least 400, the 1250 will be a good choice. Below that you better be spinning 9000 +.
Mark Whitener [url=www.racingfuelsystems.com[/url]
[Re: AndyF]
#1929759
10/10/15 07:47 PM
10/10/15 07:47 PM
Posts: 732 eastern,Ky
70RT Charger
eastern,Ky
Quick rule of thumb is HP x 1.4 = CFM. So you need to be making about 900 hp before you need 1250 cfm. Just how true is this? If it is I see ALOT of guys running way to big of a carb. 530 HP builds with 950 carbs. By that math figure it should be running a 750. If you used a 750 instead would you still have 530 HP?
