A-Body 440 Shifter cable routing #1926154
10/05/15 12:13 PM
10/05/15 12:13 PM
Canada
Mofopar Offline OP
Mofopar  Offline OP
Canada
Just broke the shifter cable (Quarter Stick) in my 72 Duster. Previous owner ran the cable out the passenger side of trans tunnel making a sharp turn into the mounting bracket.
Want to avoid another break. Show me how/where you have yours run. My replacement cable is 60" .
Re: A-Body 440 Shifter cable routing [Re: Mofopar] #1926448
10/05/15 06:47 PM
10/05/15 06:47 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
My cable runs thru the firewall over the bellshousing and down to the shift lever.Never broke or burned a cable.
Nautilus Racing-
Re: A-Body 440 Shifter cable routing [Re: Mofopar] #1926453
10/05/15 06:51 PM
10/05/15 06:51 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
You could measure and use a shorter cable.
Re: A-Body 440 Shifter cable routing [Re: Chris2581] #1926948
10/06/15 12:00 PM
10/06/15 12:00 PM
Canada
Mofopar Offline OP
Mofopar  Offline OP
Canada
What side of the firewall? Driver or passenger?
I'm thinking of going right under/beside the steering column.
Re: A-Body 440 Shifter cable routing [Re: stumpy] #1926949
10/06/15 12:01 PM
10/06/15 12:01 PM
Canada
Mofopar Offline OP
Mofopar  Offline OP
Canada
I could only seem to get a double eyelet in 60". A foot longer would smooth out the tight radius.
Re: A-Body 440 Shifter cable routing [Re: Mofopar] #1927390
10/06/15 11:29 PM
10/06/15 11:29 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I fought this battle on my Hemi Dart project. Everything was in the way of anything I tried. So I had the cable come out of the shifter and go to the passenger side and loop around the tranny to the driver side where I anchored the end of the cable to the stud at the kick down linkage pivot on the tranny bell shousing. And then welded a pivot on the adjuster threads and used that to connect to the shift lever.
In essence, I switched the anchor and the shifter lever locations.
Works great and I have had no cable problems.
Master, again and still
Re: A-Body 440 Shifter cable routing [Re: Mofopar] #1928093
10/08/15 12:20 AM
10/08/15 12:20 AM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Middle of firewall.
Nautilus Racing-
