Re: A-Body 440 Shifter cable routing
[Re: Mofopar]
#1926448
10/05/15 06:47 PM
10/05/15 06:47 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
My cable runs thru the firewall over the bellshousing and down to the shift lever.Never broke or burned a cable.
[Re: Chris2581]
#1926948
10/06/15 12:00 PM
10/06/15 12:00 PM
Posts: 183 Canada
Mofopar
Canada
My cable runs thru the firewall over the bellshousing and down to the shift lever.Never broke or burned a cable. What side of the firewall? Driver or passenger? I'm thinking of going right under/beside the steering column.
[Re: stumpy]
#1926949
10/06/15 12:01 PM
10/06/15 12:01 PM
Posts: 183 Canada
Mofopar
Canada
You could measure and use a shorter cable. I could only seem to get a double eyelet in 60". A foot longer would smooth out the tight radius.
[Re: Mofopar]
#1927390
10/06/15 11:29 PM
10/06/15 11:29 PM
Posts: 12,080 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I fought this battle on my Hemi Dart project. Everything was in the way of anything I tried. So I had the cable come out of the shifter and go to the passenger side and loop around the tranny to the driver side where I anchored the end of the cable to the stud at the kick down linkage pivot on the tranny bell shousing. And then welded a pivot on the adjuster threads and used that to connect to the shift lever.
In essence, I switched the anchor and the shifter lever locations.
Works great and I have had no cable problems.
Master, again and still
[Re: Mofopar]
#1928093
10/08/15 12:20 AM
10/08/15 12:20 AM
Chris2581
Jacksonville, FL
My cable runs thru the firewall over the bellshousing and down to the shift lever.Never broke or burned a cable. What side of the firewall? Driver or passenger? I'm thinking of going right under/beside the steering column. Middle of firewall.
