Page 1 of 3 1 2 3
Engine plate with stock water pump & alternator tech help #1927646
10/07/15 12:09 PM
10/07/15 12:09 PM
Chicago adjacent
WS68SSC Offline OP
Newest
WS68SSC  Offline OP
Newest
Chicago adjacent
I have a 1968 Dodge Dart that has a stock 6 cylinder k-frame.
I am installing a 440 & 727.
I am using TTI headers.
The 1968 Dodge Dart has a manual steering box.
Has anyone been able to use a stock water pump housing(passengers side drop outlet).
Has anyone been able to use a stock factory alternator?
If so, please post what you had to do.
Where and how did you mount the alternator?
Did you have to use shims? If so what thickness? Where did you buy them?
Where did you buy the engine plate?
I WILL NOT use a GM alternator! flame
It is frustrating because everyone keeps telling me how "cheap" an engine plate will be. An engine plate is cheap until you start looking at the prices of the special alternators, special alternator brackets, and electric water pumps.
Thanks!
Re: Engine plate with stock water pump & alternator tech help [Re: WS68SSC] #1927654
10/07/15 12:17 PM
10/07/15 12:17 PM
an8sec70cuda Offline
Is this a street car or drag car?
If drag only, you can use a stock water pump setup and just use the cheap Moroso water pump drive kit to turn the factory water pump.
If street driven, take your water pump housing and have the back of it (the block mounting surface) milled down the thickness of your motorplate. Or you can use a crank pulley spacer (the thickness of the plate) to push the pulley out so it lines up w/ the water pump pulley.
There are a lot of different factory pulleys out there with different offsets.
I'm no help on the factory alternator...I went w/ a low mount GM alternator setup.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Engine plate with stock water pump & alternator tech help [Re: WS68SSC] #1927658
10/07/15 12:18 PM
10/07/15 12:18 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Just mill the thickness of the motor plate off the block side of the waterpump housing ... done.
Re: Engine plate with stock water pump & alternator tech help [Re: JohnRR] #1927666
10/07/15 12:29 PM
10/07/15 12:29 PM
Chicago adjacent
WS68SSC Offline OP
Newest
WS68SSC  Offline OP
Newest
Chicago adjacent
Re: Engine plate with stock water pump & alternator tech help [Re: JohnRR] #1927668
10/07/15 12:30 PM
10/07/15 12:30 PM
Chicago adjacent
WS68SSC Offline OP
Newest
WS68SSC  Offline OP
Newest
Chicago adjacent
I just had the motor rebuilt. Its complete. Hasn't even been fired.
I am not sure where I would even go to have this done.
Re: Engine plate with stock water pump & alternator tech help [Re: WS68SSC] #1927689
10/07/15 01:02 PM
10/07/15 01:02 PM
Just pull the water pump housing off the motor and take it to a machine shop. They can mill the back side of it to compensate for the thickness of the plate.
Make sure you know what plate you're gonna use beforehand. The AR engineering plates are .375" thick, The normal Comp Eng. plates are only .250" thick.
CHIP
Re: Engine plate with stock water pump & alternator tech help [Re: WS68SSC] #1927708
10/07/15 01:47 PM
10/07/15 01:47 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Use the AR-Engineering plate, it's nice. I use it along with a stock type water pump housing, I haven't had it milled because my pulleys line up good. But I only have 2.75 inches between the water pump snout and my radiator, so I use a cheap flex fan along with a shroud.
I use a Toyota Denso alternator and will never go back to a mopar setup, it's small, mounted low, and charges at 14 volts at all times, best setup I've ever owned. I'm sure alot of guys have the mopar setups ironed out but I always had problems with them.
Re: Engine plate with stock water pump & alternator tech help [Re: WS68SSC] #1927712
10/07/15 01:51 PM
10/07/15 01:51 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Re: Engine plate with stock water pump & alternator tech help [Re: WS68SSC] #1927717
10/07/15 02:05 PM
10/07/15 02:05 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
It doesn't have to be a GM alternator, although I don't see why that's an issue. It just needs to be an internally regulated one wire alternator, which as stated, can come from many sources. They are small, light, easy to mount and flat work better
Re: Engine plate with stock water pump & alternator tech help [Re: WS68SSC] #1927727
10/07/15 02:19 PM
10/07/15 02:19 PM
AndyF Offline
AndyF  Offline
You can use a stock water pump if you use a pulley spacer. Or machine down the water pump housing to use a stock pulley arrangement. Most people use an electric water pump of some sort when running a motor plate.
There is no simple way to use a stock Mopar alternator with a motor plate. The Mopar alternator is big, heavy and obsolete so most people building race cars get rid of them and use a modern alternator.
Re: Engine plate with stock water pump & alternator tech help [Re: Monte_Smith] #1927751
10/07/15 02:59 PM
10/07/15 02:59 PM
Chicago adjacent
WS68SSC Offline OP
Newest
WS68SSC  Offline OP
Newest
Chicago adjacent
DODGE OR DIE BABY! LOL
Re: Engine plate with stock water pump & alternator tech help [Re: WS68SSC] #1927782
10/07/15 03:58 PM
10/07/15 03:58 PM
Addison,IL
OUTLAWSSAA Offline
OUTLAWSSAA  Offline
Addison,IL
DODGE OR DIE BABY! LOL [/quote]
Ya, I thought the same thing at the beginning until I realized that the mopar alternator doesn't charge on the idle, and on a race car there's a lot of idleing. Do yourself a favor and buy a East Coast 1 wire alternator.
Re: Engine plate with stock water pump & alternator tech help [Re: WS68SSC] #1927858
10/07/15 06:08 PM
10/07/15 06:08 PM
Chicago adjacent
WS68SSC Offline OP
Newest
WS68SSC  Offline OP
Newest
Chicago adjacent
As long as it does not resemble a GM alternator I would entertain it.
Re: Engine plate with stock water pump & alternator tech help [Re: WS68SSC] #1927964
10/07/15 08:52 PM
10/07/15 08:52 PM
Ft. Wayne, IN.
Q
QTR MILR Offline
QTR MILR  Offline
Q
Ft. Wayne, IN.
I used a Denso alternator. Drilled a hole for the top bolt of the alt on the bottom of the motor plate and fabbed up my own bracket for the bottom hole. I just made spacers to line it up with... Simple, easy and cheap!!
Scott
69 Satellite, 3650lb street car... Dunnuck Racing pump gas 440. Best of 10:60@127...
Re: Engine plate with stock water pump & alternator tech help [Re: JohnRR] #1927974
10/07/15 09:10 PM
10/07/15 09:10 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
That's what I do, mill the rear of the housing .400" when using a 3/8" motor plate (extra .025" for the second gasket).
Re: Engine plate with stock water pump & alternator tech help [Re: WS68SSC] #1927997
10/07/15 09:58 PM
10/07/15 09:58 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
What exactly does a GM alternator LOOK like? They are made by Delco-Remy, who also sells alternators to GM, Ford, Chrysler and about every other manufacturer, same as Denso and others. You do realize that likely the steering gearbox and pump on your later model Chrysler product is made by Saginaw.........a GM owned company. Oh noooooooooo............LOL!!!!
Re: Engine plate with stock water pump & alternator tech help [Re: WS68SSC] #1928100
10/08/15 12:26 AM
10/08/15 12:26 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I can't add much to the discussion other than saying a GM alternator(CS130) was one of the best things I have ever done to my car.
68 Barracuda Formula S 340
Re: Engine plate with stock water pump & alternator tech help [Re: Monte_Smith] #1928154
10/08/15 02:32 AM
10/08/15 02:32 AM
Chicago adjacent
WS68SSC Offline OP
Newest
WS68SSC  Offline OP
Newest
Chicago adjacent
Correct..."late model Chrysler product". Not on my Mopar muscle car!!!
I don't want anything even GM related even near my car lol.
Re: Engine plate with stock water pump & alternator tech help [Re: WS68SSC] #1928155
10/08/15 02:33 AM
10/08/15 02:33 AM
Chicago adjacent
WS68SSC Offline OP
Newest
WS68SSC  Offline OP
Newest
Chicago adjacent
I bought a set of used CPPA engine mounts today from a member that are believed to be made for my headers.
Hopefully this will solve the problem!
I will post pictures this weekend.
Again thanks guys for the help!
Re: Engine plate with stock water pump & alternator tech help [Re: WS68SSC] #1928235
10/08/15 10:27 AM
10/08/15 10:27 AM
That "GM product" alternator would be the best thing you could do to your mopar for a charging system.
CHIP
Page 1 of 3 1 2 3
