Engine plate with stock water pump & alternator tech help
#1927646
10/07/15 12:09 PM
10/07/15 12:09 PM
Posts: 299 Chicago adjacent
WS68SSC
Newest
Newest
Chicago adjacent
I have a 1968 Dodge Dart that has a stock 6 cylinder k-frame. I am installing a 440 & 727. I am using TTI headers. The 1968 Dodge Dart has a manual steering box.
Has anyone been able to use a stock water pump housing(passengers side drop outlet).
Has anyone been able to use a stock factory alternator?
If so, please post what you had to do. Where and how did you mount the alternator? Did you have to use shims? If so what thickness? Where did you buy them? Where did you buy the engine plate?
I WILL NOT use a GM alternator!
It is frustrating because everyone keeps telling me how "cheap" an engine plate will be. An engine plate is cheap until you start looking at the prices of the special alternators, special alternator brackets, and electric water pumps.
Thanks!
Re: Engine plate with stock water pump & alternator tech help
[Re: WS68SSC]
#1927654
10/07/15 12:17 PM
10/07/15 12:17 PM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
Is this a street car or drag car? If drag only, you can use a stock water pump setup and just use the cheap Moroso water pump drive kit to turn the factory water pump.
If street driven, take your water pump housing and have the back of it (the block mounting surface) milled down the thickness of your motorplate. Or you can use a crank pulley spacer (the thickness of the plate) to push the pulley out so it lines up w/ the water pump pulley. There are a lot of different factory pulleys out there with different offsets.
I'm no help on the factory alternator...I went w/ a low mount GM alternator setup.
[Re: WS68SSC]
#1927658
10/07/15 12:18 PM
10/07/15 12:18 PM
Posts: 75,042 U.S.S.A.
JohnRR
U.S.S.A.
Just mill the thickness of the motor plate off the block side of the waterpump housing ... done.
[Re: JohnRR]
#1927668
10/07/15 12:30 PM
10/07/15 12:30 PM
WS68SSC
Newest
Newest
Chicago adjacent
Just mill the thickness of the motor plate off the block side of the waterpump housing ... done. I just had the motor rebuilt. Its complete. Hasn't even been fired. I am not sure where I would even go to have this done.
[Re: WS68SSC]
#1927689
10/07/15 01:02 PM
10/07/15 01:02 PM
an8sec70cuda
Just pull the water pump housing off the motor and take it to a machine shop. They can mill the back side of it to compensate for the thickness of the plate.
Make sure you know what plate you're gonna use beforehand. The AR engineering plates are .375" thick, The normal Comp Eng. plates are only .250" thick.
[Re: WS68SSC]
#1927708
10/07/15 01:47 PM
10/07/15 01:47 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
Use the AR-Engineering plate, it's nice. I use it along with a stock type water pump housing, I haven't had it milled because my pulleys line up good. But I only have 2.75 inches between the water pump snout and my radiator, so I use a cheap flex fan along with a shroud. I use a Toyota Denso alternator and will never go back to a mopar setup, it's small, mounted low, and charges at 14 volts at all times, best setup I've ever owned. I'm sure alot of guys have the mopar setups ironed out but I always had problems with them.
[Re: Monte_Smith]
#1927751
10/07/15 02:59 PM
10/07/15 02:59 PM
WS68SSC
Newest
Newest
Chicago adjacent
It doesn't have to be a GM alternator, although I don't see why that's an issue. It just needs to be an internally regulated one wire alternator, which as stated, can come from many sources. They are small, light, easy to mount and flat work better DODGE OR DIE BABY! LOL
[Re: WS68SSC]
#1927964
10/07/15 08:52 PM
10/07/15 08:52 PM
Posts: 240 Ft. Wayne, IN.
QTR MILR
Ft. Wayne, IN.
I used a Denso alternator. Drilled a hole for the top bolt of the alt on the bottom of the motor plate and fabbed up my own bracket for the bottom hole. I just made spacers to line it up with... Simple, easy and cheap!!
Scott
69 Satellite, 3650lb street car... Dunnuck Racing pump gas 440. Best of 10:60@127...
[Re: JohnRR]
#1927974
10/07/15 09:10 PM
10/07/15 09:10 PM
Posts: 25,842 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Just mill the thickness of the motor plate off the block side of the waterpump housing ... done. That's what I do, mill the rear of the housing .400" when using a 3/8" motor plate (extra .025" for the second gasket).
[Re: WS68SSC]
#1927997
10/07/15 09:58 PM
10/07/15 09:58 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
As long as it does not resemble a GM alternator I would entertain it. What exactly does a GM alternator LOOK like? They are made by Delco-Remy, who also sells alternators to GM, Ford, Chrysler and about every other manufacturer, same as Denso and others. You do realize that likely the steering gearbox and pump on your later model Chrysler product is made by Saginaw.........a GM owned company. Oh noooooooooo............LOL!!!!
[Re: WS68SSC]
#1928100
10/08/15 12:26 AM
10/08/15 12:26 AM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
I can't add much to the discussion other than saying a GM alternator(CS130) was one of the best things I have ever done to my car.
68 Barracuda Formula S 340
[Re: Monte_Smith]
#1928154
10/08/15 02:32 AM
10/08/15 02:32 AM
WS68SSC
Newest
Newest
Chicago adjacent
As long as it does not resemble a GM alternator I would entertain it. What exactly does a GM alternator LOOK like? They are made by Delco-Remy, who also sells alternators to GM, Ford, Chrysler and about every other manufacturer, same as Denso and others. You do realize that likely the steering gearbox and pump on your later model Chrysler product is made by Saginaw.........a GM owned company. Oh noooooooooo............LOL!!!! Correct..."late model Chrysler product". Not on my Mopar muscle car!!! I don't want anything even GM related even near my car lol.
[Re: WS68SSC]
#1928235
10/08/15 10:27 AM
10/08/15 10:27 AM
an8sec70cuda
That "GM product" alternator would be the best thing you could do to your mopar for a charging system.
