72 Bbody clutch safety switch #1927001
10/06/15 01:02 PM
10/06/15 01:02 PM
upstate western ny
sogtx Offline OP
sogtx  Offline OP
upstate western ny
Any ideas who repops ?
Hanks in advance
Re: 72 Bbody clutch safety switch [Re: sogtx] #1927046
10/06/15 02:27 PM
10/06/15 02:27 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I don't think there is a repop.
Will an A body switch work , I have one?
Re: 72 Bbody clutch safety switch [Re: sogtx] #1927051
10/06/15 02:36 PM
10/06/15 02:36 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
Do you have one that needs repaired?
Jim at JS Restoration just did my switch. A lot cheaper than that price too. If there was a repop Brewers would be the first place to look.
Re: 72 Bbody clutch safety switch [Re: sogtx] #1927332
10/06/15 10:03 PM
10/06/15 10:03 PM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
Why do you need it?
Starting the cat with the clutch pedal in is not good for the thrust bearing.
Re: 72 Bbody clutch safety switch [Re: ThermoQuad] #1927366
10/06/15 10:45 PM
10/06/15 10:45 PM
upstate western ny
sogtx Offline OP
sogtx  Offline OP
upstate western ny
Fuel injected now ...
Leave it to me ..
Rubber bumpers dont come cheap ...
Re: 72 Bbody clutch safety switch [Re: sogtx] #1927511
10/07/15 02:43 AM
10/07/15 02:43 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Leave it to me ..
FI doesn't matter, it's still hard on the thrust bearing. There's a reason Chrysler did not use them in the 60s and then again in the 80s...I'd fab up a neutral switch on the shifter before I'd ever run a clutch switch...BUT I've never felt the need for one, especially after losing a thrust bearing in a 273 many years ago...
Re: 72 Bbody clutch safety switch [Re: Jim_Lusk] #1927539
10/07/15 07:20 AM
10/07/15 07:20 AM
upstate western ny
sogtx Offline OP
sogtx  Offline OP
upstate western ny
Ok ..
I guess ill fab up a different method to be cautious .
I just figured that the fi engine is going to zip to life little quicker than normal .
If anyone has ever used a different method , id appreciate
Some examples or methods ....
drive
Re: 72 Bbody clutch safety switch [Re: sogtx] #1927561
10/07/15 09:51 AM
10/07/15 09:51 AM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
Just run a wire from starter relay to ground, or get a pre '70 manual trans starter relay for the cleanest look. My '08 JK Wrangler has a clutch switch and I'm glad for it. And I never had an issue with the T. O. Bearing on my Bee with the clutch switch so will be reinstalling it just because it's supposed to be there. If you're not using the reverse lockout, just pull it into neutral before putting in the key.
Re: 72 Bbody clutch safety switch [Re: Pynzo] #1927926
10/07/15 07:38 PM
10/07/15 07:38 PM
upstate western ny
sogtx Offline OP
sogtx  Offline OP
upstate western ny
That's the whole reason because of the dementia problems is to remember putting it into neutral- screw the switch Id put a paperclip in between the connectorsif i had a problem with the switch Lol ..
Re: 72 Bbody clutch safety switch [Re: sogtx] #1927942
10/07/15 08:10 PM
10/07/15 08:10 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
Brewers core charge is less than the only original switch on eBay. What's your bumper worth? More than $250? Buy the whole rig from Brewers and have some peace of mind.
Re: 72 Bbody clutch safety switch [Re: Pynzo] #1928032
10/07/15 10:53 PM
10/07/15 10:53 PM
IN
ahy Offline
ahy  Offline
IN
Starter relay to ground works for me for both clutch and NSS. Agree why do you need it?
Re: 72 Bbody clutch safety switch [Re: Pynzo] #1928181
10/08/15 04:05 AM
10/08/15 04:05 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
It's not the throwout bearing that it's an issue with, it's the thrust bearing in the engine.
Re: 72 Bbody clutch safety switch [Re: Jim_Lusk] #1928201
10/08/15 08:14 AM
10/08/15 08:14 AM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
I replaced the crank bearings many years ago. The original thrust bearing was fine. This car saw 22 years of daily driving before replacement of bearings, multiple starts per day, with a clutch safety switch.
What problems have you experienced?
Re: 72 Bbody clutch safety switch [Re: sogtx] #1928223
10/08/15 10:01 AM
10/08/15 10:01 AM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
Put one of these on your shifter-
Re: 72 Bbody clutch safety switch [Re: sogtx] #1928225
10/08/15 10:06 AM
10/08/15 10:06 AM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
Change in Harleys to fuel injection around 2000.. Started using my clutch everytime before starting ( I know different mechanicals) when I witnessed a fuel injected bike start in gear and watched it climb a chain link fence at the Harley dealer.. Just didn't want to die with fuel injection..
It was a bad day for someone.....
Re: 72 Bbody clutch safety switch [Re: Pynzo] #1928286
10/08/15 12:09 PM
10/08/15 12:09 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
After reading all the posts and reading your responses it only makes sense for you to pony up the money and buy the switch.
When I do a motor for a car with a clutch I modify the thrust bearing bearing so it pushes a pressurized oil stream back on that surface just for the concerns some have stated above.
Re: 72 Bbody clutch safety switch [Re: Pynzo] #1928452
10/08/15 04:19 PM
10/08/15 04:19 PM
upstate western ny
sogtx Offline OP
sogtx  Offline OP
upstate western ny
See my post somewhere about how to customize a lift off hood ...
Re: 72 Bbody clutch safety switch [Re: JohnRR] #1928514
10/08/15 06:31 PM
10/08/15 06:31 PM
upstate western ny
sogtx Offline OP
sogtx  Offline OP
upstate western ny
Thats a pretty slick - when i blow up this 6.1 im bringin it over John..
