Would you trust this Block?? #1925503
10/04/15 12:04 PM
10/04/15 12:04 PM
St.Clairsville Ohio
EV2RUNNER Offline OP
St.Clairsville Ohio
Would you guys trust this block? I can buy it fairly reasonable and even tough it seems to be a 78 dated block they said its a forged crank, judging by the other pics he sent the counterweights don't seem to have casting marks and looks like forged crank...BUT the block has a repair done down and across a freeze plug hole, he said a shop did it, the pic looks decent but new paint can hide alot. What do you think, worth messing with or not? Thanks
Re: Would you trust this Block?? [Re: EV2RUNNER] #1925517
10/04/15 12:17 PM
10/04/15 12:17 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Pass and get another one, while it's probably fine for most street builds, 440 blocks are not that hard to find and later year castings are not that expensive. Why risk building an expensive house on a sand foundation for no good reason?
Re: Would you trust this Block?? [Re: EV2RUNNER] #1925528
10/04/15 12:44 PM
10/04/15 12:44 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
there's alot of blocks around in the mid 70's...cast damper would be a thicker one than forged and I "think 73 was the last year for forged....BUT....I see no issue with a cast crank for street and occasional track
Re: Would you trust this Block?? [Re: EV2RUNNER] #1925581
10/04/15 02:17 PM
10/04/15 02:17 PM
I bought the orginal 400 motor out of a 1976 3/4 ton pickup that was a 4 speed 4WHD that had spun a rod bearing, it had a thin dampener and a forged steel crankshaft in it shruggyMaybe that 440 was in a stick shift vechicle confused
Re: Would you trust this Block?? [Re: EV2RUNNER] #1925593
10/04/15 02:35 PM
10/04/15 02:35 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Have the block X-rayed...
If the repair was done properly, I'd have no problem running it...
Seen much worse...
Re: Would you trust this Block?? [Re: ScottSmith_Harms] #1925627
10/04/15 03:24 PM
10/04/15 03:24 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
iagree
Might be a big mistake $$ wise. And myself, I would always wonder ??? whistling
Re: Would you trust this Block?? [Re: EV2RUNNER] #1925699
10/04/15 06:10 PM
10/04/15 06:10 PM
New Jersey, USA
Y
yella71 Offline
yella71  Offline
Y
New Jersey, USA
First off whats "a reasonable price"? second whats special about this block that your looking at it in the first place? All machine work done? or needs every thing? Yes I would trust and have had a block welded in that very spot. But I owned it already. There are a lot of 440 blocks out there to chose from. Gotta have a plan and a budget . as for the crank well... with out seeing it my self I can't tell you. Good luck
71 challenger convertable, 64 sport fury 383 ci with factory air 99 sebring convertable 89 CTD pup
Re: Would you trust this Block?? [Re: EV2RUNNER] #1925954
10/05/15 12:57 AM
10/05/15 12:57 AM
St.Clairsville Ohio
St.Clairsville Ohio
Well pretty much its about cost, the price is $150 for block caps and crank. Really nothing at all special about it, just seemed cheap and my 440 in my truck is getting tired.I figured maybe I'd grab this and build another motor for it. No HP build for sure, more of a towing cam and bigger springs and that's about it pretty much stock build.
Re: Would you trust this Block?? [Re: EV2RUNNER] #1925959
10/05/15 01:00 AM
10/05/15 01:00 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
not worth the risk when it's fairly easy to find a 440
Re: Would you trust this Block?? [Re: ScottSmith_Harms] #1926072
10/05/15 09:46 AM
10/05/15 09:46 AM
Slidell, LA
Plum440 Offline
Plum440  Offline
Slidell, LA
This....
70 Challenger, 440, 4-speed, pLuM cRaZy
71 VW Super Beetle Convertible, Lemon Yellow
A couple of Jeeps…
Re: Would you trust this Block?? [Re: EV2RUNNER] #1926086
10/05/15 10:18 AM
10/05/15 10:18 AM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
$150 is no bargain for that, if the crank is truely a steel crank that changes it a little for me but without it being checked you don't knwo what it will take to get it true.
Careful, your character's showing!
Re: Would you trust this Block?? [Re: mopar346] #1926101
10/05/15 10:40 AM
10/05/15 10:40 AM
I'm wondering if it was low on antifreeze & that caused the crack & if it cracked anywhere else that they did not know of. Since it was welded they obviously then ran it & maybe it leaked elsewhere cuz now it is torn down again or maybe they welded it & did not run it. However just me I'd be tempted to try it but I would see what is avail up there for blocks & as said it might be best to not take a chance with your time and money. The steel crank is worth $150
Re: Would you trust this Block?? [Re: EV2RUNNER] #1926168
10/05/15 12:25 PM
10/05/15 12:25 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
$5 would be no bargain. 440 blocks aren't rare. Go find another one.
2011 Drag Pak Challenger
Re: Would you trust this Block?? [Re: terzmo] #1926202
10/05/15 01:20 PM
10/05/15 01:20 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
All manual trans B and RB engines were forged crank until they stopped production.
Kevin
Re: Would you trust this Block?? [Re: Twostick] #1926502
10/05/15 08:03 PM
10/05/15 08:03 PM
Good info Kevin
Re: Would you trust this Block?? [Re: EV2RUNNER] #1926523
10/05/15 08:40 PM
10/05/15 08:40 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
Just repaired a similar block and after the repair they found a crack in the adjacent cylinder. It froze and expanded both ways. That was a 69 Charger R/T block and I felt it was worth fixing! Get another one!!!!1
