Re: Would you trust this Block??
[Re: EV2RUNNER]
#1925581
10/04/15 02:17 PM
10/04/15 02:17 PM
Posts: 43,228 Bend,OR USA
Cab_Burge
I bought the orginal 400 motor out of a 1976 3/4 ton pickup that was a 4 speed 4WHD that had spun a rod bearing, it had a thin dampener and a forged steel crankshaft in it Maybe that 440 was in a stick shift vechicle
[Re: EV2RUNNER]
#1925699
10/04/15 06:10 PM
10/04/15 06:10 PM
Posts: 1,406 New Jersey, USA
yella71
New Jersey, USA
First off whats "a reasonable price"? second whats special about this block that your looking at it in the first place? All machine work done? or needs every thing? Yes I would trust and have had a block welded in that very spot. But I owned it already. There are a lot of 440 blocks out there to chose from. Gotta have a plan and a budget . as for the crank well... with out seeing it my self I can't tell you. Good luck
71 challenger convertable, 64 sport fury 383 ci with factory air
99 sebring convertable
89 CTD pup
[Re: ScottSmith_Harms]
#1926072
10/05/15 09:46 AM
10/05/15 09:46 AM
Posts: 1,499 Slidell, LA
Plum440
Slidell, LA
Pass and get another one, while it's probably fine for most street builds, 440 blocks are not that hard to find and later year castings are not that expensive. Why risk building an expensive house on a sand foundation for no good reason? This....
70 Challenger, 440, 4-speed, pLuM cRaZy 71 VW Super Beetle Convertible, Lemon Yellow A couple of Jeeps…
[Re: EV2RUNNER]
#1926086
10/05/15 10:18 AM
10/05/15 10:18 AM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
$150 is no bargain for that, if the crank is truely a steel crank that changes it a little for me but without it being checked you don't knwo what it will take to get it true.
Careful, your character's showing!
[Re: mopar346]
#1926101
10/05/15 10:40 AM
10/05/15 10:40 AM
RapidRobert
I'm wondering if it was low on antifreeze & that caused the crack & if it cracked anywhere else that they did not know of. Since it was welded they obviously then ran it & maybe it leaked elsewhere cuz now it is torn down again or maybe they welded it & did not run it. However just me I'd be tempted to try it but I would see what is avail up there for blocks & as said it might be best to not take a chance with your time and money. The steel crank is worth $150
[Re: terzmo]
#1926202
10/05/15 01:20 PM
10/05/15 01:20 PM
Posts: 6,566 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
there's alot of blocks around in the mid 70's...cast damper would be a thicker one than forged and I "think 73 was the last year for forged....BUT....I see no issue with a cast crank for street and occasional track All manual trans B and RB engines were forged crank until they stopped production. Kevin
[Re: Twostick]
#1926502
10/05/15 08:03 PM
10/05/15 08:03 PM
RapidRobert
All manual trans B and RB engines were forged crank until they stopped production. Good info Kevin
