ID numbers on a '65 Barracuda #1925163
10/03/15 09:11 PM
10/03/15 09:11 PM
North Carolina
apairof66s Offline OP
North Carolina
I've got a '65 Barracuda that I'm trying to locate the body numbers to match the vin. Any advice ?
Re: ID numbers on a '65 Barracuda [Re: apairof66s] #1925203
10/03/15 09:56 PM
10/03/15 09:56 PM
try the transverse across rad top support bar and the rear package tray near the speaker openings on the dr side toward the base of the rear glass. might be another just cant remember right now. EDIT might be one on the wheelwell bulges on the inside of the car I forget which side
Re: ID numbers on a '65 Barracuda [Re: RapidRobert] #1925268
10/03/15 11:35 PM
10/03/15 11:35 PM
North Carolina
North Carolina
Thanks for the reply. I will check it and post what I find.
Re: ID numbers on a '65 Barracuda [Re: apairof66s] #1925312
10/04/15 12:48 AM
10/04/15 12:48 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
You are not going to find body numbers that match the VIN on a 65 anything, I think 68 was the first year for that.
You'll find SO numbers, but those are not VIN numbers and the only thing I am aware of that will tie an SO to a VIN number would be the broadcast sheet. But I ain't a numbers guy so YMMV.
Don't be the exception.
Re: ID numbers on a '65 Barracuda [Re: Supercuda] #1925380
10/04/15 02:24 AM
10/04/15 02:24 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
'69 was the first year. Otherwise, you are correct.
Re: ID numbers on a '65 Barracuda [Re: Jim_Lusk] #1925496
10/04/15 11:56 AM
10/04/15 11:56 AM
North Carolina
North Carolina
The numbers on the core support are 5700108188. These are probably the same on other places on the car.
Of course the vin starts with 1852.
Chances of finding the broadcast sheet is out of the question. The interior has been partly removed and has been sitting for years.
