Page 10 of 13 1 2 8 9 10 11 12 13
Re: "Custom 33" [Re: dogdays] #1922531
09/30/15 03:38 PM
09/30/15 03:38 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Originally Posted By dogdays
Please remind me how to apply POR-15. Spray or brush? Or how?
Thanks,
R.
I think you can go both ways, but I brushed my stuff. Lays down well if you use a fine brush. Did the calipers with their caliper paint to handle the heat. Por 15 satin color matched the powder coat satin real close. Did the exhaust system in black satin ceramic coating, which matched the other coatings also. It will be pretty boring under there, but it should hold up will when I am off roading. beer
Fastest 300
Re: "Custom 33" [Re: Crizila] #1922782
09/30/15 09:25 PM
09/30/15 09:25 PM
moparx Online content
moparx  Online Content
it's nice to see progress is being made ! up but one thing jumps out at me concerning your trailer hitch. in using what amounts to be an open channel, it seems that opens up a good opportunity for a twisting, or a collapse of the drop due to insufficient gusseting, even though it appears to be made of thick enough [1/4" ?] material. and even if the trailer is a light loaded deal, i have seen similar setups twist up like a pretzel during my brothers stint as a "gofer" for the local u-haul dealer in his younger years. you have done excellent work so far, so please don't take this as a slam. i sure would hate to see anything happen when you are done, then have to go back and re do the hitch.
beer
Re: "Custom 33" [Re: moparx] #1923219
10/01/15 12:23 PM
10/01/15 12:23 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Thanks for the hitch input. Had to drop the receiver down that far to clear the rear roll pan. Yes, 1/4" plate for mount. Empty trailer weight ( fiberglass box on a simple square frame ) is approx. 350 lbs ( tires and all ). Can't see it over 1000 lbs. gross. For and aft won't be a problem, but might consider "boxing in" the down section to address your twisting concerns. Thanks again for the input.
Fastest 300
Re: "Custom 33" [Re: Crizila] #1923717
10/01/15 09:15 PM
10/01/15 09:15 PM
Lehigh Acres, Florida
rickstershemi Offline
Looks awesome !!!!!
Rickster
Re: "Custom 33" [Re: rickstershemi] #1924215
10/02/15 03:29 PM
10/02/15 03:29 PM
dogdays Offline
dogdays  Offline
Re: trailer hitch
1. Needs to be boxed for sideways loads. Even pulling the trailer around a curve will cause it to deflect sideways and probably twist.
2. Rear crossmember appears to be a C-channel, which is very weak in torsion. Meaning the trailer hitch is going to cause it to twist. I'd suggest boxing it for at least 3/4 of the total length, boxing centered in the middle. In other words you could leave 6" or so open on each side to allow wiring, etc to be run inside the box. The box doesn't need to be real thick, but 3/16" would be good is my SWAG.
It all looks so clean, makes me wish for a garage.....
R.
Re: "Custom 33" [Re: dogdays] #1924317
10/02/15 06:02 PM
10/02/15 06:02 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Re: trailer hitch
R.
10-4 on #1. Rear cross member is 3/16" square tubing. Same as rest of frame. No problem there. Body will be coming back off in 2-3 weeks for paint. I will box in the hitch mount then. Appreciate the input from everyone. It's one reason why I post pictures. bow
Fastest 300
Re: "Custom 33" [Re: Crizila] #1933622
10/17/15 01:21 AM
10/17/15 01:21 AM
Az
Crizila Offline OP
Crizila  Offline OP
Az
After a little over 1 year of work, it went off to paint and interior today.
Fastest 300
Re: "Custom 33" [Re: Crizila] #1934134
10/18/15 07:19 AM
10/18/15 07:19 AM
you,sir, shall be congratulated for making excellent progress on a fine,fun ride. up i wish i lived closer so i could talk you into giving me a ride when it emerges all shiny and comfortable ! can't wait until the final results !
beer
Re: "Custom 33" [Re: moparx] #1934231
10/18/15 12:54 PM
10/18/15 12:54 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Thank you. I hope you are right and I won't have to send it back to the manufacturer for too many recalls. wave
Fastest 300
Re: "Custom 33" [Re: Crizila] #1946477
11/06/15 06:40 PM
11/06/15 06:40 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Well, the Chassis is loaded and ready to go when ever the body comes back from paint and interior. Peace a cake putting stuff on the chassis without the body in place. grin Relocating the alternator low and left has just about made reading the timing marks impossible, so I'm thinking of relocating them to the passenger side ( side the hood will open up on anyway). Boxed in the trailer hitch receiver. Receiver will also hold license plate when I am not towing - have yet to fab up. I'm thinking the exhaust system might be a little loud with straight through Borla's. Might change later. Light at the end of the tunnel is now a night light size. wave
Fastest 300
Re: "Custom 33" [Re: Crizila] #1946481
11/06/15 06:42 PM
11/06/15 06:42 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
few more pics
Fastest 300
Re: "Custom 33" [Re: Crizila] #1946798
11/07/15 09:36 AM
11/07/15 09:36 AM
looks good john. up i wish i was about 1/4 as much along as you are on my humpback ! keep after it. you should be running by early next year ? beer
Re: "Custom 33" [Re: moparx] #1946827
11/07/15 11:31 AM
11/07/15 11:31 AM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Thanks Moparx! Ya, shootin for about mid summer to get it on the road - if all works out.
Fastest 300
Re: "Custom 33" [Re: Crizila] #1958412
11/26/15 04:14 PM
11/26/15 04:14 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
Getting closer. Body is in paint and interior is coming together.
Fastest 300
Re: "Custom 33" [Re: Crizila] #1958711
11/27/15 11:57 AM
11/27/15 11:57 AM
i didn't realize what color your were going with. i like that choice a lot ! up up
beer
Re: "Custom 33" [Re: moparx] #1958783
11/27/15 02:32 PM
11/27/15 02:32 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
beer
Thanks, it's a Dodge truck color - Western brown pearl.
Fastest 300
Re: "Custom 33" [Re: Crizila] #1967008
12/10/15 12:56 PM
12/10/15 12:56 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
in paint.
Fastest 300
Re: "Custom 33" [Re: Crizila] #1967011
12/10/15 12:57 PM
12/10/15 12:57 PM
Az
Crizila Offline OP
Crizila  Offline OP
Az
A few more
Fastest 300
Re: "Custom 33" [Re: Crizila] #1967090
12/10/15 02:53 PM
12/10/15 02:53 PM
Looks Awesome...Love the color...Hurry UP....LOL
Rickster
Re: "Custom 33" [Re: Crizila] #1967185
12/10/15 04:38 PM
12/10/15 04:38 PM
WOW ! eek stunning to say the least ! excellent color choice; you shouldn't see too many at the cruise like that ! sure wish i lived closer to see it in person.
beer
