trans mount in 727 #192324
01/13/09 06:01 PM
01/13/09 06:01 PM
Annapolis, Missouri USA
CIB Offline OP
CIB  Offline OP
I have a 65 belvedere 727 . the numbers on trans say a 1968 model. Yet when I took mount off bolt holes on tailshaft were 4 inchs apart. Is it possible some mated a 65 tailshaft to a 68 trans? I had already ordered the special mount from schmacher.
Re: trans mount in 727 [Re: CIB] #192325
01/13/09 07:08 PM
01/13/09 07:08 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If the trans is cable shifted and has a 4-inch bolt spread on the mounting pad it's a pre-66. The early and late tailhousings won't interchange.
What numbers make you think it's a '68? If the build date following the part number is '68 it's possible that a replacement trans was built at a later date.
Re: trans mount in 727 [Re: John_Kunkel] #192326
01/13/09 07:20 PM
01/13/09 07:20 PM
CIB Offline OP
CIB  Offline OP
It is a cable shift on an external lever. I ran numbers on trans came out as belonging to a 68 383.
Re: trans mount in 727 [Re: CIB] #192327
01/14/09 04:12 PM
01/14/09 04:12 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The bolt centers on a '66 and later mount pad should be about 2 3/4".
