Re: trans mount in 727
[Re: CIB]
#192325
01/13/09 07:08 PM
01/13/09 07:08 PM
Posts: 25,885 Rio Linda, CA
John_Kunkel
Rio Linda, CA
If the trans is cable shifted and has a 4-inch bolt spread on the mounting pad it's a pre-66. The early and late tailhousings won't interchange.
What numbers make you think it's a '68? If the build date following the part number is '68 it's possible that a replacement trans was built at a later date.
[Re: CIB]
#192327
01/14/09 04:12 PM
01/14/09 04:12 PM
John_Kunkel
Rio Linda, CA
The bolt centers on a '66 and later mount pad should be about 2 3/4".
