518 tranny? #1921648
09/29/15 02:54 AM
09/29/15 02:54 AM
Canada
WO23Coronet Offline OP
Canada
Looking at buying a 360 w/a 4spd auto out of a 1990 1/2 ton extended cab long box. I haven't seen it yet but I'm guessing this would for sure be a 518 (46RH) tranny?
Re: 518 tranny? [Re: WO23Coronet] #1921802
09/29/15 02:34 PM
09/29/15 02:34 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
yep
Re: 518 tranny? [Re: WO23Coronet] #1921860
09/29/15 04:09 PM
09/29/15 04:09 PM
Canada
Canada
Thx for the response. I know never say never but I was pretty sure it would be a 518, just wanted to be fairly certain before I drive 2 hrs to go get it. I only want the tranny (future project of putting it in my '67 Coronet) but I have to take the 360 with it. Wish I had a use for the 360 cause it's a pretty sweet small block. 308 heads (high swirl intake with a W2 exhaust port), a roller cam and it's still an LA, probably try to sell it but if it doesn't sell I'll moth ball it in the corner and save it.
Re: 518 tranny? [Re: WO23Coronet] #1923226
10/01/15 12:36 PM
10/01/15 12:36 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
if it turns out to be a 500 all is not lost--the old 904s are built up to drag racing strength with 999 internals...been running a 500 on my 64 for 10+ years....
Re: 518 tranny? [Re: WO23Coronet] #1923396
10/01/15 03:35 PM
10/01/15 03:35 PM
Guitar Jones Offline
The non magnum could possibly have the 500 in it. I've even seen them in 3/4 ton trucks back then, why? I don't know.
Re: 518 tranny? [Re: WO23Coronet] #1923398
10/01/15 03:38 PM
10/01/15 03:38 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
Being a 90 model it should be an LA Roller Cam block which are worth something to some folks...
Re: 518 tranny? [Re: WO23Coronet] #1923634
10/01/15 07:42 PM
10/01/15 07:42 PM
Canada
Canada
Thx for the extra replies. I'll just cross my fingers and hope it's a 518.
Re: 518 tranny? [Re: WO23Coronet] #1924201
10/02/15 03:16 PM
10/02/15 03:16 PM
dogdays Offline
dogdays  Offline
I wouldn't hesitate to put an A-500 in a car, if that's what it turns out to be.
R.
Re: 518 tranny? [Re: dogdays] #1924678
10/03/15 02:10 AM
10/03/15 02:10 AM
garnett kansas
rhad Offline
rhad  Offline
garnett kansas
being in a 90 model truck it might be a non lockup 518
my ladder of success is missing some rungs
Re: 518 tranny? [Re: rhad] #1924751
10/03/15 05:16 AM
10/03/15 05:16 AM
Canada
Canada
That's what I'm hoping for. I'm putting in a 727 with a CRT torque converter this spring so it would be nice to be able to reuse the TC when I do make the jump to a 518 (hoping it's a 518, it's going behind a 440 so I'd rather have the 727 based one)
Re: 518 tranny? [Re: WO23Coronet] #1924856
10/03/15 01:11 PM
10/03/15 01:11 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
You do realize that the trans will need a bellhousing swap or an adapter to bolt up to a big block.
Re: 518 tranny? [Re: WO23Coronet] #1924924
10/03/15 03:08 PM
10/03/15 03:08 PM
Canada
Canada
For sure Stumpy, I'd probably go with an adapter (also lots of cross member fabing)
