Found this N the Trans Pan. Is this a real bad thing? #19224
11/28/05 10:20 AM
11/28/05 10:20 AM
Tenn.
jrwoodjoe Offline OP
Tenn.
When working on the stripped trans pan bolt in the 65 Barracuda, I found this clip in the bottom of the transmission pan. Does anyone know where it might go and how bad a thing might this be?
Thanks, Joe
65 Barracuda
70 Challenger
Re: Found this N the Trans Pan. Is this a real bad thing? [Re: jrwoodjoe] #19225
11/28/05 10:29 AM
11/28/05 10:29 AM
N
NITROUSN Offline
NITROUSN  Offline
N
looks like the clip that holds the park rod to the valve body. either yours is off or it is an extra?
Re: Found this N the Trans Pan. Is this a real bad thing? [Re: NITROUSN] #19226
11/28/05 11:22 AM
11/28/05 11:22 AM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
that's about the only thing that I can think of that uses a clip like that.
Re: Found this N the Trans Pan. Is this a real bad thing? [Re: dartman366] #19227
11/28/05 12:21 PM
11/28/05 12:21 PM
Tenn.
Tenn.
Thanks for taking a look and giving me your thoughts. I will take a look and see if I can figure out where it goes and if it is an "extra" or not.
Thanks again.
Joe
65 Barracuda
70 Challenger
Re: Found this N the Trans Pan. Is this a real bad thing? [Re: dartman366] #19228
11/28/05 12:27 PM
11/28/05 12:27 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Theres a good chance thats what it goes too.
Good luck w/the trans
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Found this N the Trans Pan. Is this a real bad thing? [Re: GoodysGotaCuda] #19229
11/28/05 12:59 PM
11/28/05 12:59 PM
Bern, Switzerland
6o4o Offline
6o4o  Offline
Bern, Switzerland
The governor also uses this type of clips, but I don't know if that could get into the oil pan from the output shaft...
Re: Found this N the Trans Pan. Is this a real bad thing? [Re: 6o4o] #19230
11/28/05 01:13 PM
11/28/05 01:13 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
good point but it looks bigger than a govenor one ???
Re: Found this N the Trans Pan. Is this a real bad thing? [Re: jrwoodjoe] #19231
11/28/05 01:17 PM
11/28/05 01:17 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
IIRC the spring loaded shuttle valves use a clip about that size.
Re: Found this N the Trans Pan. Is this a real bad thing? [Re: JohnRR] #19232
11/28/05 01:19 PM
11/28/05 01:19 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
comparing the size of the clip to the hand that's holding it, I would say parking rod clip, unless he has really, really small hand's, the one on the govenor is quite a bit smaller than that one, I believe the stem thru the govenor is approx. 1/8 dia.
Re: Found this N the Trans Pan. Is this a real bad thing? [Re: jrwoodjoe] #19233
11/28/05 06:32 PM
11/28/05 06:32 PM
that should be a cable tranny. i'm betting the c-clip fits the little cable connector that attaches to the valve body. cable tranny's don't have the park rod that runs up to the valve body. page john kunkel, he'll know!
Re: Found this N the Trans Pan. Is this a real bad thing? #19234
11/28/05 11:19 PM
11/28/05 11:19 PM
Doesnt the governor use an internal snap ring? I would say park rod also but im not familiar with the pushbutton trannys.
Re: Found this N the Trans Pan. Is this a real bad thing? #19235
11/29/05 09:41 AM
11/29/05 09:41 AM
there isn't any park connection inside the main case of a push button trans. i've taken those little c-clips off before on my 65 trans.
Re: Found this N the Trans Pan. Is this a real bad thing? #19236
11/29/05 10:05 AM
11/29/05 10:05 AM
Tenn.
Tenn.
Thanks for the advice. This is not a push button tranny. It is floor shift.
Joe
65 Barracuda
70 Challenger
Re: Found this N the Trans Pan. Is this a real bad thing? [Re: jrwoodjoe] #19237
11/29/05 10:55 AM
11/29/05 10:55 AM
i think the only difference on a 65 floor shift tranny vs a push button is the rooster comb for the gear selector at the valve body. if its a 65 trans then its probably the c-clip for the cable connector.
Re: Found this N the Trans Pan. Is this a real bad thing? [Re: jrwoodjoe] #19238
11/29/05 04:12 PM
11/29/05 04:12 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Common e-clips:
Left is the '64-'65 shift cable adapter which is .025" thick
Second from left is the governor which is .042" thick
Second from right is the external throttle shaft
Far right is the '66-on Park rod.
Re: Found this N the Trans Pan. Is this a real bad thing? [Re: John_Kunkel] #19239
11/29/05 08:27 PM
11/29/05 08:27 PM
The Wet Coast, Canada
megajoltman Offline
megajoltman  Offline
Common e-clips:
Your the man
1969 Dart 383/727/D60
CTD Ram 4x4 Mega Cab
Procharged 350Z
Re: Found this N the Trans Pan. Is this a real bad thing? [Re: John_Kunkel] #19240
11/30/05 10:58 AM
11/30/05 10:58 AM
Tenn.
Tenn.
Common e-clips:
Thanks John. Mine measures 5/16 so it appears to be the Shift Cable Adapter clip. I have a service manual and will try to determine the location and if this is an extra or a missing one.
Thanks for taking time to post the photo and to all of you for your input. It is greatly appreciated.
Joe
65 Barracuda
70 Challenger
Re: Found this N the Trans Pan. Is this a real bad thing? [Re: jrwoodjoe] #19241
11/30/05 03:43 PM
11/30/05 03:43 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The part on the left is the adapter that uses an e-clip retainer. I suppose it's possible that it could remain in place without the clip, the part is visible with the pan removed.
Re: Found this N the Trans Pan. Is this a real bad thing? [Re: John_Kunkel] #19242
11/30/05 05:13 PM
11/30/05 05:13 PM
john, your title needs to be changed from "master" to "master tranny man".
